led dimmig
topjimmy
led dimmig
Post by topjimmy »
I am building an led fixture, it will have 4 drivers from steve's leds. I assume I am going to need the expansion mod to dim all of them to different levels, and add effects and such. Does it just connect to the head unit? What gauge wire will I need to use?
Re: led dimmig
It doesn't connect to the head unit, but the relay box.
You can use 24 gauge or lower without a problem.
topjimmy
Re: led dimmig
Post by topjimmy »
Isee. Were I to put off the mod for now, will the built in dimming be OK to hook up to all the drivers at once?
Re: led dimmig
Yes, you can hook up several as long as the maximum draw is 40mA.
topjimmy
Re: led dimmig
Post by topjimmy »
Great! That may suffice for now.
BTW what type of head does the relay side take?
Re: led dimmig
The lead wires are available on the webstore, but I think they are called 2510.
