Will the reef angel control the koralia pumps?
mason dixon
If not, does it control any brand pump besides vortech?
Re: Will the reef angel control the koralia pumps?
You can turn them on/off, but if you are talking about the controllable ones, no you cannot. It used proprietary driver that does not offer any tylenol third party control. That is the way Hydor designed it to be.
You can also control Tunze pumps by using one of the dimming channels if you have the analog type.
Sent from my SPH-D700 using Tapatalk 2
mason dixon
Thanks rimai
Is their code out there to control the tunze pumps in a similar way to vortech's settings(lagoonal, nutrient, etc)?
There is no preset code, but you control the pumps with the same code you would control lights:
The code above would have the pump set to 50%.
You can go wild and create all sorts of waveforms. If you have a Tunze and RA with analog signal, let me know what type of waveform you would like to try out and we can come up with them.
I can copy them from the RF module. If you have 2 or more Tunzes, we can even have them work in anti-sync and back-of-tank and emulate the Nutrient Transport mode of the ecotech driver
ReefAngel.PWM.SetActinic(50);
mason dixon
Awesome! I will post back here when I 've got everything setup....hopefully this June/July
mason dixon
One more question:
If my LEDS took both dimmable sockets, is there an add-on for more dimmable sockets for the tunze pumps?
Yes, I can turn the PWM expansion module into analog type signal too. That gives you an extra 6 analog dimming ports.
psyrob
Do you need to have the analog type on the main controller to be able to have a analog-converted PWM expansion module work? Or will the converted PWM work if the main controller is not the analog type? I bought my controller before there was an option for PWM or analog,, I am assuming in those days (last June) that they were all pwm instead of analog?
You are correct that all boxes purchased last June were all PWM type signal.
The convertion happens on the relay box, so the head unit won't affect the signal.
jgregory
Roberto, you mentioned above: "You can also control Tunze pumps by using one of the dimming channels if you have the analog type"
I have the PWM - are there options for me to still control a Tunze pump?
-John
-John
Unfortunately, it is not too easy without an additional piece of equipment.
You can get an expansion module with analog signal type.
timmcq
To controll a simple Koralia pump randomly on and off, i could use a wave maker type of mode, correct?
If RAGen is already set to use both dosing pumps, can another relay be used?
- DrewPalmer04
Use only relays 5 and 6. They are special for use with consistent on/off
timmcq
I'm just learning my RA. In RA Gen, on the Main Relay tab I have Ports 1 and 2 set as Dosing Pumps 1 and 2. When I select Port 5 or 6, the Wavemwker options are greyed out. How do I select 5 as a Wavemaker?
There was a change on how wm code was handled not too long ago and RAGen was never updated.
You can manually add the code or try the Reef Angel Wizard.
Open Arduino and go to menu Tools->Reef Angel Wizard
timmcq
I had not used the wizard. This is great!
Thanks Roberto!
Thanks Roberto!
- Contact:
I would suggest using the wizard. It gets updated faster than RAGen does now plus it's incorporated into Arduino. Everything is all right there. Very handy to use.timmcq wrote:I had not used the wizard. This is great!
Thanks Roberto!
