Trouble with LED PWM Output
icecool2
I'm trying to setup my LED system with the RA, but I'm not seeing any output on either of the PWM outs. Is there a test file I can test out to see if it is my code that's the problem?
icecool2
Re: Trouble with LED PWM Output
I'm running v0.8.3. I should also point out that I ordered the pwm booster, but found it rattling around inside of the relay unit when it arrived. I took it out.
icecool2
Turns out not having the booster on there is what caused the problem. If the booster isn't installed, you need to jumper across the pins to get an output. I installed two jumpers and everything is working great now.
