Hi Roberto,
I have been meaning to extend my ATO timeout for a while and did some reading up on it. I see that there has been an update to the libraries that allows this to be done on the fly. I will try and update tomorrow. Since I have wifi, do I have to go through the setup for that all over again? Can I use any of my old code for PWM slope for example?
Updating to new libraries
Re: Updating to new libraries
Yes, you can still use the old code. It is the same.
Do you use android app?
grafspee1217
No not currently, will be in a month when I upgrade my phone, why?
Just wanted to check to give you how to change the setting.
You will need to browse to http://ipaddress:2000/mb276,xxx to change the value on the fly.
grafspee1217
Once I update, I have to set up the wifi and the client again?
no. all you need to do is upload the code again.
You may need to upload the internal memory file too.
