Wifi Can't connect anymore (after board swap)
astralmind
Post by astralmind »
That's an odd one.
Replaced my RA mainboard, flashed the Init Memory file followed by my INO generated through the wizard (hardcoded values). Everything is working #1 except for the wifi module which always worked great before.
It does connect to my network instantly, slow flashing green light, gets its static IP but it ends there. Trying to reach it via my browser doesn't return anything either. (can't be reached at all, android app or portal)
I did check the "Wifi" box under acessories in the wizard.
Any thoughts ?
Re: Wifi Can't connect anymore (after board swap)
Try this?
ReefAngel.AddWifi();
astralmind
Well it's working now hmmm so all I did was play with the cable. Looks like one of the pin was not properly pushed in.. as usual stupid user error ;)
Salinity also up and running, very cool! Forgot my pH calibration settings though I should have written them somewhere, will have to buy the solutions again.
