I'd like to inform the release of the libraries version 1.0.0.
The prefered method to update is downloading the latest Reef Angel Installer, which can be found here: http://www.reefangel.com/Download.ashx
This release will come with the following:
- Arduino IDE with auto-selection of features and update checks.
- Libraries v1.0.0
- Wizard v2.0.1
There is no need for manually changing features file or using RAGen to pick your features anymore.
The file that contains all the keywords and features is located at \Documents\Arduino\update\features.txt
It also has an update check that will retrieve the latest library version and compare to the one you have currently installed in your system. This check happens eveytime you start Arduino IDE. If it finds an update, it will prompt you to download it.
The list of files to be downloaded can be found in the file \Documents\Arduino\update\source.txt
With this release, there was a change on the location of where memory settings are being stored.
This is only applicable to those that use memory settings.
The change log for the libraries is here: http://forum.reefangel.com/viewtopic.php?f=7&t=1473
After installing, you will need to reload an internal memory file to reinitialize the new memory locations.
You can do this by uploading the InitialInternalMemory file, which can be found on menu File->Sketchbook->Example Codes->InitialInternalMemory
That's it. You are ready to generate a new code with the new Reef Angel Wizard by going to menu Tools->Reef Angel Wizard
Previous internal memory codes will not work anymore. You will need to update that code by replacing the following line:
InternalMemory.IMCheck_write(0x5241494D);
InternalMemory.IMCheck_write(0xCF06A31E);
I hope you enjoy the new features and happy coding
