Internal Memory section
Hi Everyone,
I just updated the Portal code to include the Internal Memory section.
This will allow you to change some internal memory settings right in the Portal too!!
It requires dev libraries v1.0.1, which is due to be released soon.
Stay tuned!
Stay tuned!
fatman
btorrenga
Re: Internal Memory section
Awesome feature, very very explanatory and well laid out. However, I have been having trouble setting my heater on value since upgrading to dev lib 1. The value seems to be stuck at 1023. Setting it via the wizard and android app has no effect. I tried with the portal, same result. Here is the portal output when setting the memory:
Saving Internal Memory...
Controller is running dev libraries v.1.0.1
Heater On - OK
Chiller On - OK
Chiller Off - OK
Vortech Mode - ERR
Done.
Checking with the android app shows the heater on temp value is still 1023. What could be causing this value to stick like that?
Heater On - OK
Chiller On - OK
Chiller Off - OK
Vortech Mode - ERR
Done.
There was a memory table relocation on version 1.0.0
On android app, choose Settings->Settings and make sure that Pre v1.0 Locations is unchecked.
It will direct the android app to look at the new memory table.
btorrenga
Right, I found that after I upgraded to 1.0.0. The option is unchecked in the app, but the variable does not change. Could something have gotten screwed up when, after I initially upgraded to 1.0.0, I did not uncheck that option at first?
btorrenga
<M222>1023</M222>
Is that a default value from when I upgraded to 1.0.0?
yes, that's the default value.
Now, what happens when you browse:
http://ipaddress:2000/mi222,780
That should put the 780 value in the memory. Does it do that?
Did you run the memory conversion code or loaded a new memory file at all?
http://forum.reefangel.com/viewtopic.php?f=7&t=1477
btorrenga
<M222>OK</M222>
And then the result of http://ipaddress:2000/mi222 is
<M222>1022</M222>
Which is especially odd, isn't it???
<M222>1022</M222>
btorrenga
rimai wrote:Did you run the memory conversion code or loaded a new memory file at all?
I loaded a new memory file created with the wizard
Is it just the heater memory location?
Can you post what you get with /mr?
btorrenga
As far as I know it is the only memory section that gives this issue. Here is /mr (not sure what it means):
<MEM>
0D0016FF0C001600FFFFFFFF07FFFFFF78003E030000FE031603390334033C63031C020AFFFFFFFFFFFFFF3C00FFFF0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF100EFFFFFFFFFFFF3CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0AFFFFFFFFFFFFFFFF
</MEM>-
If you try to change the hearter off, chiller on and chiller off, does it take those?
btorrenga
Yes, I can successfully change all of those values.
Humm.. Let's see what happens if you change a byte long variable.
Try /mb222,100
Then read the byte value too with /mb222
What do you get?
Try /mb222,100
What do you get?
btorrenga
Result of /mb222,100:
<M222>OK</M222>
Result of /mb222:
<M222>254</M222>
<M222>OK</M222>
Result of /mb222:
<M222>254</M222>
It looks like your memory is somehow not saving it
I think the only solution is replace it. There isn't a way to replace the memory.
PM me.
PM me.
