Custom display
Appleseed
Custom display
Post by Appleseed »
  // Globals Needed for RF Mode on Custom Main
    byte vtechmode;
    byte vtechspeed;
    byte vtechpercent;
    boolean bFeeding=false;
      byte x = 6;
      byte y = 2;
      byte t;
      char text[7];
    //Custom Main, Graph & Menu
//      ReefAngel.LCD.DrawDate(6, 2);
      ReefAngel.LCD.DrawText(3,255,6,2," Reef of Low");
      ReefAngel.LCD.DrawDate(7, 99);
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
      ReefAngel.LCD.DrawText(0,255,18,21,"EcoSmart Vortech");
      if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,32,"Constant");
      else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,31,"Lagoon");
      else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,31,"Reef Crest");
      else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,31,"Short Pulse");
      else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,31,"Long Pulse");
      else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,31,"Nutrient Trnsp.");
      else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,31,"Tidal Swell");
      else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,31,"Night");
      ReefAngel.LCD.DrawText(0,255,10,50,"Tank");
      ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 10, 60, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,100,50,"pH");
      ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 85, 60, text, Num8x8);
      ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
    ReefAngel.FeedingModePorts = Port4Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 290 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1,251,261 );
    ReefAngel.StandardHeater( Port2,251,261 );
    ReefAngel.StandardFan( Port3,271,281 );
    ReefAngel.StandardLights( Port5,20,0,5,0 );
    ReefAngel.StandardLights( Port6,20,0,0,0 );
/////// CHANGE MODE @ TIMES
if ( ReefAngel.RF.Mode != Feeding_Start)
          if (hour()==10)
            ReefAngel.RF.SetMode( ReefCrest,30,20);
         else if (hour()>=6 || hour()<9)
            ReefAngel.RF.SetMode(ReefCrest,20,10);
         else if (hour()>=9 && hour()<10)
            ReefAngel.RF.SetMode(ReefCrest,30,10);
         else if (hour()>=10 && hour()<11)
            ReefAngel.RF.SetMode(ReefCrest,40,10);
          else if (hour()>=11 && hour()<12)
            ReefAngel.RF.SetMode(Smart_NTM,50,6);
          else if (hour()>=12 && hour()<13)
            ReefAngel.RF.SetMode(Smart_NTM,60,10);
          else if (hour()>=13 && hour()<14)
            ReefAngel.RF.SetMode(Smart_NTM,70,12);
          else if (hour()>=14 && hour()<15)
          else if (hour()>=15 && hour()<16)
            ReefAngel.RF.SetMode(Smart_NTM,50,8);
          else if (hour()>=16 && hour()<17)
            ReefAngel.RF.SetMode(Constant,50,10);
          else if (hour()>=17 && hour()<18)
            ReefAngel.RF.SetMode(Constant,40,10);
          else if (hour()>=18 && hour()<19)
            ReefAngel.RF.SetMode(Constant,30,10);
          else if (hour()>=19 && hour()<20)
          else if (hour()>=20 && hour()<21)
          else if (hour()>=21 && hour()<22)
          else if (hour()>=22 || hour()<23)
          else if (hour()>=23 || hour()<0)
            ReefAngel.RF.SetMode(ReefCrest,60,10);
          else if (hour()>=0 || hour()<1)
            ReefAngel.RF.SetMode(ReefCrest,50,10);
          else if (hour()>=1 || hour()<3)
         else if (hour()>=3 || hour()<6)
    ReefAngel.Portal( "appleseed" );
Hello all,
I have been trying to get my display to show the mode that my vortechs are in (using code borrowed from people on here much smarter than me), the code currently only ever displays tha tthe pumps are in Constant mode but the led on the rf module shows that actual mode being not constant.
Can some one advise where I am going wrong?
cheers
Andy
Re: Custom display
You need to assign the rf mode to the variable vortechmode:
vtechmode=ReefAngel.RF.Mode;
Try this:
byte vtechmode;
byte vtechspeed;
byte vtechpercent;
byte x = 6;
byte y = 2;
byte t;
char text[7];
    if (hour()==10)
Appleseed
Re: Custom display
Post by Appleseed »
Thanks Roberto that's sorted it.
One more question on this topic if I may? Is it possible to display the speed and duration as well?
thanks
Andy
Re: Custom display
Yeah, you can use ReefAngel.RF.Speed and ReefAngel.RF.Duration in your DrawCustomMain() function.
Appleseed
Re: Custom display
Post by Appleseed »
      vtechspeed=ReefAngel.RF.Speed;
      vtechpercent=ReefAngel.RF.Duration
ReefAngel.LCD.DrawText(0,255,18,21,"Vortech Speed");  //ignore x,y for now
//    if (vtechspeed )ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,32,"Some Text");
ReefAngel.LCD.DrawText(0,255,18,21,"Vortech Duration"); //ignore x,y for now
//    if (vtechpercent) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,32,"Some Text");
thanks for the info, but I am not sure how to do this :oops: I am guessing the code above is a start but I have no clue what to do...
Also when the mode text changes it leaves some of the previous text in the "background" I know I read somewhere that this is easy to sort out but I could not find the thread. So it would be good if you can point me in the right direction :oops: i am guessing ReefAngel.LCD.Clear is the way forward but again dummy here has no clue :cry:
Re: Custom display
You are getting there.
Just replace "Some Text" with vtechspeed and vtechpercent :)
To erase previous draw, you can use:
ReefAngel.LCD.Clear (255,35,32,60,42);
255= 8 bit color code
35 = x1
32 = y1
60 = x2
42 = y2
where x1 and y1 is the left top point of the rectangular you want to clear and x2 and y2 is the bottom right point.
Re: Custom display
Appleseed
Re: Custom display
Post by Appleseed »
rimai wrote:You are getting there.
Hi Roberto,
I must be missing something as I tried the following;
ReefAngel.LCD.DrawText(2,255,32,42,"Speed");
if (vtechspeed) ReefAngel.LCD.DrawLargeText(0,255,35,51,"vtechspeed");
ReefAngel.LCD.DrawText(23,255,32,62,"Duration");
if (vtechpercent) ReefAngel.LCD.DrawLargeText(0,255,35,70,"vtechpercent");
But the screen displays vtechspeed and vtechpercent instead of the actual values.
Re: Custom display
Remove of the quote marks.
Quote marks means text.
if (vtechspeed) ReefAngel.LCD.DrawLargeText(0,255,35,51,vtechspeed);
Appleseed
Re: Custom display
Post by Appleseed »
I tried that but I got the following error;
Seventh_attempt.cpp: In function 'void DrawCustomMain()':
Seventh_attempt:81: error: invalid conversion from 'byte' to 'char*'
Seventh_attempt:81: error: initializing argument 5 of 'void RA_NokiaLCD::DrawLargeText(byte, byte, byte, byte, char*, byte)'
Seventh_attempt:84: error: invalid conversion from 'byte' to 'char*'
Seventh_attempt:84: error: initializing argument 5 of 'void RA_NokiaLCD::DrawLargeText(byte, byte, byte, byte, char*, byte)'
Re: Custom display
Sorry.
I just realized that you are using DrawLargeText.
Use this then:
  ConvertNumToString(text, vtechspeed, 1);
  if (vtechspeed )ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,32,text);
  ConvertNumToString(text, vtechpercent, 1);
  if (vtechpercent) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,32,text);
Appleseed
Re: Custom display
Post by Appleseed »
Thanks for that Roberto is working just how I wanted it :D :D :D
