Hello,
I have been using the portal quite successfully for a little while now and Iv noticed for about a week, maybe less, that while I can use it to control my tank, the relay's and vortech modes don't update.
I use the Android app remotely on my phone so I know that it does work on port 2000.
Is it possible it could be a server side issue?
Cheers
Matt
Portal half working
eds
eds
Re: Portal half working
It does.
Last Update:
Thu Jul 26 2012 17:51:22 GMT+1000 (E. Australia Standard Time)
Displaying data from:
Reef Angel Controller (live)
It is very odd, I can control the relays, but they don't display the correct status. The temps work but the vortech module is wrong. The android app works outside brilliantly. Very confusing
Last Update:
I think it is because the controller is not sending the updated info to the server.
The last update the server has was on Jul 13th.
It's either that your code does not have the Portal() function or your wifi attachment is not configured correctly.
eds
here is my existing code
Also I havnt changed anything
Last Update:
Fri Jul 27 2012 14:41:38 GMT+1000 (E. Australia Standard Time)
So something very odd is happening.
Iv not changed anything in my config// Autogenerated file by RAGen (v1.2.1.158), (03/08/2012 22:54)
// RA_030812_2254.ino
#define DisplayImages
#define DateTimeSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define SaveRelayState
#define RelayExp
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x16
#define NUMBERS_8x16
#include <avr/wdt.h>
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 PWM channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
// Globals Needed for Params on Custom Main
byte x,y;
int v;
byte vtechmode;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Matt's Reef Tank ");
// Display T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Tank");
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
// Display the T2 Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Canopy");
// Display the T2 Temp Value
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
// Display Vortech MP40wES Mode Header Text
ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox(13, 109, TempRelay);
//Draw Date & Time
void DrawCustomGraph() // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit |Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.StandardATO(Box1_Port4,30);
ReefAngel.Relay.On(Port1); //Radion1
ReefAngel.Relay.On(Port2); //Radion2
ReefAngel.Relay.On(Port3); //Radion3
ReefAngel.Relay.On(Port4); //Vortech1
ReefAngel.Relay.On(Port5); //Vortech2
ReefAngel.Relay.On(Port6); //Vortech3
ReefAngel.Relay.On(Box1_Port1); //NP Biopellets
ReefAngel.Relay.On(Box1_Port2); //Dosing Pump
ReefAngel.Relay.On(Box1_Port7); //Return Pump
//--------------------------------------------------------- RF Module Setup -------------------------------------------------------
ReefAngel.RF.SetMode(Slave_Start,0,0);
If you get a compile error similar to this:
'class ReefAngelClass' has no member named 'RF'
Please make sure that you enabled RF Expansion on your features file.
Open RAGen and make sure you have RF Expansion checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
#define RFEXPANSION
InternalMemory.RFMode_write(1);
InternalMemory.RFSpeed_write(70);
//------------------------------------------------------ End RF Module Setup ------------------------------------------------------
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
// Specific functions
ReefAngel.Refresh(); //WDT check
ReefAngel.StandardHeater(Box1_Port7 );
ReefAngel.Portal("eds");
//------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//------------------------------ Start Feeding Mode Schedule (Start 1st Feeding at 9:55 AM and 2nd at 1:55 PM)---------------------
// if the hour is 9a or 1p, minute is 55 and seconds is 0
// start the feeding mode
if ( ((hour() == 9) || (hour() == 13)) &&
(minute() == 55) &&
(second() == 0) )
ReefAngel.FeedingModeStart();
vtechmode = InternalMemory.RFMode_read();
//------------------------------------------------------ End of Feeding Mode Schedule ---------------------------------------------
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
if (hour() >=8 && hour() <= 22)
if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
bFeeding=false;
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,100,5);
ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
ReefAngel.Timer[4].Start();
vtechmode = 5;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
ReefAngel.RF.UseMemory=true;
//---------------------------------------------------------- End RF Daytime Control -----------------------------------------------
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=23 || hour()<7) // Defining "Nightmode" hours for VorTech = between 11 PM and 7 AM
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
//------------------------------------------------------ End Time-of-Day Based Functions ------------------------------------------
//--------------------------------------------------------------- End Loop --------------------------------------------------------
Last Update:
Oh, your code is missing some stuff and some functions are also in the wrong sequence of events.
Try this:
Try this:
#define wifi
#define RelayExp
#define WDT
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x16
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
0,0,0,0,0,0};
byte x,y;
int v;
byte vtechmode;
//Top Banner
char text[7];
// Display pH Value
//Draw Date & Time
#define RFEXPANSION
//#define Night 9
//#define None 99
(minute() == 55) &&
(second() == 0) )
bFeeding=false;
vtechmode = 5;
vtechmode = 9;
