When posting for help, it would be beneficial if you could provide the following information in your post:
- What libraries you are using: Preloaded or Main/Development
- What version of the libraries you are using
- If it is an application you are having problems with, what version of the application you are using.
- If you are having problems with a INO/Sketch, attach the INO/Sketch to the post (if possible) or paste the section of the code inside the CODE tags.
