Troubleshooting LCD screen
ahmedess
Sometimes when i press the push button on the controller i get a blank screen instead of the main display screen and it stays like that until i unplug the controller from power and replug it back in
ahmedess
Re: Troubleshooting LCD screen
Yes. It also flikers when its blank like that
ahmedess
// Autogenerated file by RAGen (v1.2.1.158), (03/12/2012 20:24)
// RA_031212_2024.ino
#define DisplayLEDPWM
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 4
#define PWMEXPANSION
#define CUSTOM_MAIN
#define SALINITYEXPANSION
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "pH calibration";
prog_char menu3_label[] PROGMEM = "Salinity calibration";
menu0_label, menu1_label, menu2_label, menu3_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.SetupCalibratePH();
void MenuEntry4()
ReefAngel.SetupCalibrateSalinity();
ReefAngel.LCD.DrawDate(6, 6);
ReefAngel.LCD.DrawMonitor(15, 45, ReefAngel.Params, ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawMonitor(15, 45, ReefAngel.Params);
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15, 75, "SL:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Salinity, COLOR_BLACK, 35, 75, 10);
//ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
// Specific functions
ReefAngel.StandardFan(Port2);
ReefAngel.Relay.DelayedOn(Port8, 5);
ReefAngel.Portal("ahmedess", "xxxxxxx");
ReefAngel.DosingPumpRepeat1(4);
ReefAngel.DosingPumpRepeat2(5);
ReefAngel.PWM.SetActinic(PWMSlope(15,05,23,54,0,InternalMemory.LEDPWMActinic_read(),60,ReefAngel.PWM.GetActinicValue()));
ReefAngel.PWM.SetDaylight(PWMSlope(15,0,23,59,0,InternalMemory.LEDPWMDaylight_read(),120,ReefAngel.PWM.GetDaylightValue()));
I don't see anything wrong except for the Portal() function, which should be just above ReefAngel.ShowInterface();
ahmedess
It doesnt happen all the time but its been happening more often lately
Was there anything added lately? Equipment change or anything?
ahmedess
It also stays lit for longer than the specified LCD timeout
I can't replicate the problem.
What happens if you remove the jumpers from the head unit?
This will disable your expansion modules, though.
Sent from my SPH-D700 using Tapatalk 2
ahmedess
I uploaded the code again to the controller after fixing the code as you mentioned and i ll test and see
