SingleATOLow not working properly
alexwbush
Post by alexwbush »
I am not sure what I am doing wrong here. I have a set of float switches wired in series (for redundancy) plugged into ATOLow that controls my ATO (port 8). Thoughts?
It works when I hard code ATOLow to turn on/off port 8, but I don't get the 60 second timeout:
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.DayLights( Port1 );
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.StandardHeater( Port6 );
//    ReefAngel.SingleATOLow( Port8 );
    if ( ReefAngel.LowATO.IsActive() )
       ReefAngel.Relay.On(Port8);
       ReefAngel.Relay.Off(Port8);
    ReefAngel.Portal( "alexwbush" );
But this won't work (using SingleATOLow). It'll work the first time but then never comes back on when the water level is too low:
alexwbush
Re: SingleATOLow not working properly
Post by alexwbush »
And it really doesn't make sense because the portal is showing my ATOLow as active (green), so why isn't it triggering?
alexwbush
Post by alexwbush »
Is there an easy code I can add to see the up to the minute status of the ATOs on the display? Maybe to replace the graphs. I think my 2 wire plug in port may be malfunctioning or loose.
Both are working for me here.
Add this to your code inside the loop() section:
      ReefAngel.LCD.Clear(0,10,120,18,128);
      ReefAngel.LCD.Clear(255,10,120,18,128);
This will draw a square below the time to indicate when the ATO port is active or not.
alexwbush
Post by alexwbush »
thanks for the code Roberto. The ATO switches are working great and accurate. For some reason it's not triggering the relay to turn on. Could it be there is something wrong with the timer being reset? It seems that it only does it once, then never again right after I load the code.
You just found a bug on the Wizard.
The Wizard is missing the setting for hour interval.
That's why it only runs once. It's waiting for X hours before it can run again.
Since it is not setting the X in your memory, it is using whatever you've got in the memory right now.
You can use Java Status app or Android app to change it or you may load the InitialInternalMemory code or add this to your setup():
I need to add this memory location to both Wizard and Portal.
This will save 0 into your memory settings.
alexwbush
Post by alexwbush »
awesome! I updated the memory using the Android app... THANKS!
