1. According to my RA distributor the PH probe requires no calibration out the box - Is this correct?
2. Where do is set date and time on the controller?
thanks for the help
New user Issue
ishtak
Re: New user Issue
Lockes,
You will need to calibrate the PH probe. You need the 7 and 10ph liquid to do it. If you are in JHB you are welcome to borrow my samples to do your calibration. Or if you are on MASA check with Poiromaniax, I think he may have some left (he purchased rather large bottles to do his).
Date and time can be set from a variety of places. If you are using the standard menus, as far as I remember, you can select it from there. Or if you have the WIFI attachment you can do it from either the Client Suite (windows) or the Android App.
Lemme know if you need any first hand help. I'll be happy to lend a hand if I can
Justin
Justin
Lockes
Re: New user Issue
That's great
Can you also use 7 & 4 as I can pick this up close to my office
ishtak
