Need Help with Setup
Gideon1
Hello all, just got the new RA+ and WiFi, I all totally lost, I am no coder, thought I'd get some help from you guys. I am on OXs mountain lion tried to upload Arduino with codes got error. Relay box is clicking on the RA screen T2 Error and T3 error. Here is the codes load I think:
he following features were automatically added:
Watchdog Timer
Version Menu
Simple Menu
core.a(main.cpp.o): In function `main':
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:5: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:15: undefined reference to `loop'
UIDefaults.getUI() failed: no ComponentUI class for: com.l2fprod.common.swing.JTaskPane[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=,minimumSize=,preferredSize=]
java.lang.Error
at javax.swing.UIDefaults.getUIError(UIDefaults.java:712)
at javax.swing.MultiUIDefaults.getUIError(MultiUIDefaults.java:133)
at javax.swing.UIDefaults.getUI(UIDefaults.java:742)
at javax.swing.UIManager.getUI(UIManager.java:1001)
at com.l2fprod.common.swing.plaf.LookAndFeelAddons.getUI(LookAndFeelAddons.java:270)
at com.l2fprod.common.swing.JTaskPane.updateUI(JTaskPane.java:121)
at com.l2fprod.common.swing.JTaskPane.<init>(JTaskPane.java:111)
at com.reefangel.tool.Wizard.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:682)
at java.awt.EventQueue.access$000(EventQueue.java:85)
at java.awt.EventQueue$1.run(EventQueue.java:643)
at java.awt.EventQueue$1.run(EventQueue.java:641)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:652)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.l2fprod.common.swing.plaf.LookAndFeelAddons.getUI(LookAndFeelAddons.java:275)
Watchdog Timer
Version Menu
Simple Menu
java.lang.Error
Gideon1
Re: Need Help with Setup
Hi Thanks for getting back with me. I have unintalled RA+ on my OSX and I am using Paralles 7 win Ardunio for inniall setup it's much easier it seems, i'll keep you posted. Q: relay box is making clicking sounds?
That's the sound of relays clicking.
The preloaded code comes with wavemaker ports that alternate every few seconds.
Gideon1
I followed instruction to the key but still get "No internal Memory Found" on the RA+ display? What am I doing wrong
Thx
Thx
Gideon1
Heres whats on the Ardunio:
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port2,21,0,7,0 );
ReefAngel.StandardLights( Port3,7,0,21,0 );
ReefAngel.StandardLights( Port4,7,0,21,0 );
ReefAngel.Portal( "Gideon1" );
You missed the step where you have to upload the internal memory.
http://www.reefangel.com/Support.Loadin ... tings.ashx
Gideon1
RA wisdor says download completed successfully but RA + displays say "No internal memory found" Joy stick no response. What is going on here...plese help Thanks!
Gideon1
rimai...thanks it appears to be up and running. I have to test and make adjustment now....you are great! Thanks Now i need to setup my wiifii
Gideon1
Status light is red on RA + ? what does this mean?
Gideon1
Hi rami,
I am unable to setup my wifii. Here are the codes what am i doing wrong Thx:
InternalMemory.OverheatTemp_write( 807 );
The code has nothing to do with how you setup your wifi.
Did you read the manual?
Also, please check this thread:
http://forum.reefangel.com/viewtopic.php?f=15&t=345
Gideon1
Can't connect to wifi followed steps, my home network is via time capsule wired to my FIOS router, when i type SSID and password for my home network does not connect, or should it be my FIOS i connect too???...
tired that too no connection, i get a slow green blinking light on the wifi unit? How do i connect, and resolve the issue. I did port forwarding to port 2000, to no avail. I do not know what I'm doing wrong. Please help.
~ben
~ben
If you get slow green and no blue, you should be connected to your wifi.
Can you see the wifi attachment in your attached devices of your router?
Gideon1
I do get a slow green light but all "false indicators" with wifi status, do i need to upload test for wifi page?
Gideon1
if connected to wifi sholud I still be getting "Unreachable Address" in portal, i can't update, and still get false indicators ie wifi status: Auth...etc
Oh, if you are getting false on auth and dhcp and 0.0.0.0 ip address, then something is not setup right, indeed.
Can you try another wifi utility?
https://github.com/davemolton/Graphical ... ves/master
Try setting up with Daves wifi utility.
Make sure you connect at 57600 baud.
Gideon1
I can not verify wifi is setup...please help
alexwbush
what is the utility telling you?
http://forum.reefangel.com/viewtopic.php?f=15&t=345 <-pretty straight forward
