Android RA Status Auto Selection
chase
Is there a way to set ports back to auto once they have been toggled off/on via the app? Seems like if I override a port I have to go to the portal to switch it back to auto. Thanks!
- Contact:
Re: Android RA Status Auto Selection
yes. When you toggle them on or off, there is a green ball / icon that appears to the right of the toggle button. if you tap it, that returns the port back to auto mode.chase wrote:Is there a way to set ports back to auto once they have been toggled off/on via the app? Seems like if I override a port I have to go to the portal to switch it back to auto. Thanks!
chase
- Contact:
yeah, i really need to write a guide to using it but i just simply have not taken the time.chase wrote:Hah, awesome...been using this forever and never knew that.
chase
No worries. Due to the amount of support you guys provide via the forums I find a lot of the answers I need, or at least enough to figure things out when I get stuck
