moonlight module questions
dadriance
Post by dadriance »
I'm trying to decide between building a moonlight function into my (under construction) DIY LED fixture or simply adding RA's module(s). Am I correct in thinking that I may need more than )1 module for a 90 gal (48x18) tank and that I'd need a PWM channel for each one? How many modules would I need for this tank size?
Re: moonlight module questions
Correct.
I'd say at least 3 moonlights and 4 or 5 would be optimal.
dadriance
Post by dadriance »
Thanks Roberto. 3-4 modules plus an additional pwm module to run them is probably not my best option. I may end up just putting a few LEDs on a seperate driver and running it off a single PWM channel.
Piper
Post by Piper »
Is it possible to run more than one moonlight off of a single PWM port? I just picked up two moonlights because I only have the two ports available but I thought I just read a post here somewhere that said you can run more than one light per port.
~Charlie
no. just one moonlight per channel.
you can run multiple led drivers, but not the dimmable moonlights.
Piper
Post by Piper »
Ahh, got it. That must have been what I read.
How about on a 36 inch tank, would I be ok with 2?
I have 2 in my 36" tank and it is fine to me.
I do have some darker spots, but it's ok to me.
