Does it support ? Any program needed ?
Thanks a million
Does reef angel support email alert sending ?
Re: Does reef angel support email alert sending ?
Yes, you can use this function:
But, there is a better feature coming up. Stay tuned.
void WifiSendAlert(byte id, boolean IsAlert)
static byte alert_status;
if (IsAlert)
if ((alert_status & 1<<(id-1))==0)
alert_status|=1<<(id-1);
Serial.print("GET /status/alert.asp?e=5555555555@messaging.sprintpcs.com&id=");
Serial.println(alert_status,DEC);
Serial.println("\n\n");
if (id==0)
alert_status=0;
delay(900);
alert_status&=~(1<<(id-1));
chercm
Where do u specify the email address ?
Is this "new" feature out yet? I'm using a gravity fed ATO and hoping to send an alert if my reservoir is low...and maybe the other if any drain issue and DT is filling..
You can do it in the Portal.
Pretty much all triggers can be set.
rossbryant1956
Roberto helped me do something like this. Check out our conversation on page 4 of this post. Works like a charm:
http://forum.reefangel.com/viewtopic.ph ... 5&start=30
