Wifi Periodically Stops Responding
agentgreen
Re: Wifi Periodically Stops Responding
That did it. Thanks!
Now, let's put stuff back to the way it was.
set d n www.reefangel.com
set i h 198.171.134.6
save
reboot
agentgreen
rockin!
appreciate it as always!
kimacom
is this also same problem with WIFI?
connection is unreachable but update is still working time to time?
Reef Angel wifi address:
75.84.228.xxx:2000 (update)
My reefangelid:
kimacom
Connection Status:
Unreachable Address
Last Update:
2012년 8월 7일 화요일 오전 9:55:14
Displaying data from:
Webbanner database
My reefangelid:
kimacom
Connection Status:
Unreachable Address
Last Update:
Webbanner database
In your case, I think you need to setup port forwarding.
Did you do that?
If you can access the controller by browsing to http://75.84.228.xxx:2000, the portal can too.
Did you do that?
kimacom
yesterday i can access the controller by browsing to that ip
but not today, i think it's peoridically diconnect and connect...
how do i set up port forwading?
your ip may have changed too.
Internet providers often change ip addresses too.
Port forwarding is something you setup in your router.
Try this:
http://www.simpleportforwarding.com/
http://portforward.com/routers.htm
Try this:
kimacom
ok i will try at home with router
thanks, roberto.
tim
thanks, roberto.
tim
kimacom
wow it works
just simple is that.
port forwarding works
thank you so much
you saved my life
thank you so much
you saved my life
kimacom
oh, one more question
is it actually different ip address to access controller
from home and any other place using 3G?
my iphone works 3G good anywhere but not at home which is connected by wifi.
i have to change ip address as router's
no other way not to change ip add?
Yeah, they are different.
But you should be able to use the same ip you use on 3G both at home or outside.
If it does not work, it is a limitation of your router
kimacom
yes i can use 3G at home to access controller
but i have to turn off my wifi on iphone, right?
That's what I trying to say.
It should work even with your wifi turned on.
If it does not work it is because your router doesn't allow it. I think it is called loopback calls.
I have a cisco router and it does not allow me to do it
Most home routers do allow it though.
kimacom
hmm
so if i adjust my router, i can access through wifi to 3G ip address?
that's exactly what i am looking for.
how to?
how to?
Have you tried using the 3G ip address when you are connected in your wifi??
What happens?
What happens?
kimacom
I was trying 3G ip address into iphone with wifi at home, it did not work.
But my work place, i am also using wifi with 3G ip address, it is working.
So, i think I can use 3G ip address with different wifi like guest wifi.
My router has dual band as guest, i have not try yet, but i think it will work.
thanks roberto.
thanks roberto.
Amos Poh
Sometime in the future, you won't have to manually check your tank on your phone....your phone will do it automatically for you. That simply means that I'm going to be adding an "auto update" feature to the app and widget(s) to display on the home screen.binder wrote:ishtak wrote:Awesome news! Thanks Curt ... I'm having with drawl symptoms not being able to check my tank on my phone every 5 minutes
looking forward to this
ahmedess
I've tested setting the host to 0.0.0.0 and it still times out
Are you using the 2.35 firmware?
Have you tried the Tera Term config file I posted a couple posts back?
ahmedess
I m using 2.35. i updated to 2.35 using the wifi update utility using the instructions you gave me on this thread long time ago.
ahmedess
Heres a summarized list of all the different settings i ve tried to use to fix the wifi module time out issue with no luck:
Dhcp on or off
Host set to 0.0.0.0 or to reefangel.com
Firmware 2.35
Reserving a Static ip for the module on the router
I have discovered that sometimes when i try to connect to the wifi module using its LAN ip address and it times out that i could connect to it using its WAN ip address at the same moment without any problems, while being connected to the same network the module is on. I dont know the reason why this is happening and it doesnt make any sense because if using WAN the communication path from my pc to the router to the internet back to router then to wifi module is good then how come its not good using LAN from pc to router to wifi module?
Dhcp on or off
Firmware 2.35
Hum, that is strange indeed. It doesn't make sense to be able to connect wan and not lan.
Like you said, when you make a wan request, it has to go out to the internet and come back as opposed to lan, which would be a direct connection.
The attachment doesn't have a way to distinguish between lan or wan. So it can't discriminate your lan requests.
Have you tried the sleep/wake command yet?
http://forum.reefangel.com/viewtopic.php?p=10947#p10947
ahmedess
I just did set the sleep timer to 3600s and the wake timer to 1s, i ll test and see.
I've noticed while checking the module's settings using "get e" command something called "BCAST=255.255.255.255:55555"
what does it represent?
I don't see that in their manual.
http://rovingnetworks.com/resources/dow ... ser_Manual
Thavngr98
Has anyone tried setting the sleep timer setting? I've owned the WiFi module for 2 weeks and have had it stop responding twice, reboot of module always fixes it.
-Dave
carlli has with good results.
ahmedess
I ve tried the sleep timer but i have found that the module blinks green fast after a while and it doesnt connect, in my case. I will try to reboot every hour instead and see what it does.
ahmedess
it connects fine right after i connect the module to the controller then blinks green fast after a while and doesn't connect that is after trying the setting below:
set sys debug 0x80
set a r 3600
set sys debug 0x80
set a r 3600
fatman
Set the host to o.o.o.o and the blasted thing still disconnects. Reboot and it runs. It did run for 8 days once though. Since I'm traveling a lot I assume it reads my flight schedule somewhere and disconnects just after I board the plane. Pretty smart controller.
