Can't calibrate ph or reset ato timeout
Ask in here.
sceia
Post by sceia »
Everytime I try to press either menu item, it just returns to the main screen... Hints?
Scott.
#define AutoTopOff          1
#define Refuge              2
#define MHOuter             3
#define Actinic             4
//#define MHCenter            5
#define Heater              6
#define Moonleds            7
#define Pumps               8
#define RB         0
#define Moonlight  1  //moonlight
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu1_label[] PROGMEM = "Feed Fish";
prog_char menu2_label[] PROGMEM = "ATO Clear";
prog_char menu3_label[] PROGMEM = "Calibrate PH";
prog_char menu4_label[] PROGMEM = "-";
prog_char menu5_label[] PROGMEM = "-";
prog_char menu6_label[] PROGMEM = "-";
  menu1_label,
  menu2_label,
  menu3_label,
  menu4_label,
  menu5_label,
  menu6_label
void MenuEntry1() //"Feed Fish"
  ReefAngel.FeedingModeStart();
void MenuEntry2() //"ATO Clear"
  ReefAngel.ATOClear();
void MenuEntry3()
  ReefAngel.SetupCalibratePH();
void MenuEntry4() //"Actinic LEDs"
void MenuEntry5() //"100% Daylight LEDs"
void MenuEntry6() //"Refuge LEDs"
  //Init and custom menus
  //Menu Modes
  ReefAngel.FeedingModePorts = B10010000;
  ReefAngel.WaterChangePorts = B10010000;
  ReefAngel.OverheatShutoffPorts = B00101110;
  //Pumps and waves on
  ReefAngel.Relay.On(Pumps);  //Turn Sump/Skimmer on at startup
  //Top Off
  ReefAngel.StandardATO(AutoTopOff,25);  //Setup AutoTopOff as Auto Top-Off function with 500s timeout
  //Light Schedule
  ReefAngel.StandardLights(Refuge,19,00,14,00);  //Refugium schedule 10:00pm - 12:00am
  //ReefAngel.MHLights(MHCenter,13,0,20,0,15);
  ReefAngel.MHLights(MHOuter,13,15,20,0,15);
  ReefAngel.StandardLights(Actinic,11,0,23,0);
  ReefAngel.StandardLights(Moonleds,6,30,2,30);
  // Drivers
  ReefAngel.PWM.SetChannel(RB,PWMSlope(10,0,22,0,15,65,45,15));
  ReefAngel.PWM.SetChannel(Moonlight,25);
  //Heating/Cooling
  ReefAngel.StandardHeater(Heater,778,782);  // Setup Heater to turn on at 77.8F and off at 78.2F
Re: Can't calibrate ph or reset ato timeout
It works for me.
sceia
Post by sceia »
rimai wrote:It works for me.
I'm not sure what's up then?? All it does is go back to the main screen.... The Feed fish menu works though....
Scott.
I've seen this behavior you are describing when this line is not in the code:
But your code does have it.
