iPhone app shows current readings, but no control
estanoche
Post by estanoche »
This has been driving me nuts.... I'll admit, Ive been really slow at upgrading my firmware on my wifi to 2.35, but I did do that last week and it still didnt resolve this issue...
The RA app on my iphone, while it will quickly connect and display me my tank readings:
It refuses to connect to the control screen even after waiting several minutes:
I had a hell of a time getting the firmware to update on my wifi - had to use terra term to do it by hand as none of the utilities could get a stable connection with the unit - it is quite possible I have screwed up about 100 different settings in the process of wiping/reinstalling/wiping/resetting firmware process
Any suggestions? What else would you need to know about my programming to get a clear picture?
Re: iPhone app shows current readings, but no control
what do you have on settings->direct connection?
estanoche
Post by estanoche »
Nothing much - got my IP, port 2000, and DC set to "off"
Change direct connect to on
estanoche
Post by estanoche »
issue remains with DC "on" - actually with DC on, it hangs on both the My Tank and Control screen
Does it work if you use the internal ip address?
One thing is for sure. You need to have direct connect set to on to be able to connect to the controller and control relays. With direct connect off, it will pull the last data sent to the server.
estanoche
Post by estanoche »
rimai wrote:Does it work if you use the internal ip address?
makes sense - I'll be sure to keep the DC on..
I can connect internally - so I'm thinking its something in my router settings??? Any ideas on what I should be looking for?
If you can connect internally, make sure that your port forwarding is setup correctly in your router.
estanoche
Post by estanoche »
rimai wrote:If you can connect internally, make sure that your port forwarding is setup correctly in your router.
It is - my current suspicion is when I was wiping the wifi module I overwrote some code for the web server that indicates what types of connections its allowing.............
If you can connect internally, then it should be set up correctly.
Check the port forwarding here: http://www.yougetsignal.com/tools/open-ports/
When your router is setup correctly, it will say that the port 2000 is open.
estanoche
Post by estanoche »
hmmm yeah its showing closed ........ stupid motorola, the settings are right i swear!!
estanoche
Post by estanoche »
for sanity sake, does this look right?
CMD
get ip
IF=UP
DHCP=ON
IP=192.168.10.5:2000
NM=255.255.255.0
GW=192.168.10.1
HOST=69.198.171.165:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
<2.35> ???vk????j??=helloworld
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=MYPASSPHRASE
<2.35> get u
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
<2.35> GET /r99 HTTP/1.1
Host: 192.168.10.5:2000
Yeap. Looks correct.
Do you happen to have 2 routers?
Or maybe one modem and one router?
estanoche
Post by estanoche »
its one of those motorola surfboards - cable modem and router in the same device......
Is it wifi too?
All-in-one?
estanoche
Post by estanoche »
yup - all in one.........
estanoche
Post by estanoche »
AHA - i figured it out...
on my unit, in port forwarding I can select "both" "tcp" or "udp" as a forwarding option.... apparently, when set to both, that is no good
setting it to TCP fixed the issue
cool :)
