Got my controller,
Got my controller,
Woohoo! Got my controller hooked up to the Mac (no issues communicating!!) got the wifi module configured thru serial (Wifi Utility didn't do anything...) Connected to controller and tested through web. Port forwarding configured and working! iOS app working... Just have to configure portal now...but first, have to load some code!!!
The git commenting Doxygen step will now take a short intermission...maybe back to it later tonight or this weekend. Let the fun begin!!!
Thanks Roberto, package came nicely packed and everything looks great!!
Re: Got my controller,
So here's what I got after my first night of coding... let me know what you think.
Next up is to customize the menu and main screens to show the MoonPhase and Vortech Mode. Anyone have any input on changing the vortech mode through a custom menu? I saw the thread detailing this, but wasn't sure how that code ever ended up working...
Also need to see about working with the Sunrise/Sunset stuff I wanted to work on. But at least the controller is currently usable and ready to be connected up. Will probably code a few more features before making the swap.
Feedback is more than welcome....
byte vtechmode;
boolean bFeeding=false;
boolean isNight=false;
//Define Relay Ports
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Vortech 5
#define Heater 6
#define Refugium 7
#define UPS 8
ReefAngel.LightsOnPorts = Port4Bit | Port7Bit ;
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( UPS );
ReefAngel.Relay.DelayedOn( Vortech,5 );
ReefAngel.Relay.DelayedOn( Skimmer,5 );
ReefAngel.StandardLights( WhiteLEDs,12,0,20,0 );
ReefAngel.StandardLights( BlueLEDs,11,0,23,0 );
ReefAngel.StandardHeater( Heater,788,792 );
if (( hour() <= 11 ) || ( hour() >= 23 ))
isNight=true;
} else {
isNight=false;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
bFeeding=false;
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,155,5);
ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
ReefAngel.Timer[4].Start();
vtechmode = 5;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
if (isNight)
vtechmode = 9;
} else {
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
if (isNight)
ReefAngel.Relay.On( Refugium );
} else {
ReefAngel.PWM.SetDaylight( 0 );
ReefAngel.PWM.SetActinic( 0 );
ReefAngel.Relay.Off( Refugium );
ReefAngel.Portal( "lnevo" );
Nice job!!!
The easiest way of changing modes using the custom menu is by cycling modes everytime you choose that menu, then go to memory mode as the last choice.
If I did that, how do I prevent my loop() from reverting it back to memory mode? Also how do I set the default memory mode?
To prevent it from going back to memory mode, just use this:
It will simply ignore whatever is in the memory setting.
To change the memory setting, there are several ways:
Java status app
Android app
Portal
Built-in webserver
Java status app
Android app
Portal
Built-in webserver
Nevermind, re-reading my code, I only go back to memory mode if the timer is trigged. But can I set the default memory mode in my setup()? and change later through the apps?
Yes.
InternalMemory.RFMode_write(3);
InternalMemory.RFSpeed_write(50);
Ok, here is my current code...
I still haven't sync'd up my Vortech yet, but now that I have the laptop able to upload code, I can work on that. Also should have pH calibration fluid in the LFS by Wednesday... I still have to setup the Vortech control menu so I can play with it from the controller. (Do the mode buttons still work on the unit itself after it's sync'd?) The moonlights are hooked up and look sweet! They are really low, even on 100% which is perfect.. I just want a touch of light when everything is off so it's not so dark... Right now we're at 20% and it gives a nice glimmer. Too bad I can't get a good photo.
Anyway, does anyone have a good code to add the Vortech controls? I want to preserve most of the Simple_Menu and have to start playing around with that.
I've also added the Sunrise / Sunset, but my string writing seems a bit messed up. I think the calculations are good, but without seeing the results, it's hard to tell. It seemed about an hour off from the Utah given as the example, so I really need some time to troubleshoot. I've got the base code stripped of all weather and dimming functions, so it's pretty basic. If someone can take a look and give me another set of eyes would be great!
Anyway, here it is...sorry to be soo long winded..
//By Matthew Hockin 2012.
//SWFLTEK library functions, #includes, and #define were copied directly from the Epherma library
//Epherma (SWFLTEK.com) was written by Michael Rice- thanks Michael it works great.
//If you copy from this (its all open source) please
//acknowledge Michael for SWFLTEK library code (obviously labeled) or Matthew Hockin (for the rest).
#include <stdlib.h>
#include <math.h>
#define _sec_rad 206264.806247096370813 // arc-seconds per radian
#define _tilt 0.409092804222329 // axial tilt of earth at epoch, in radians
#define _tropical_year 31556925 // tropical year in seconds... rounding error accumulates to 26 seconds by the year 2136
#define _zenith 3.11250383272322 // 'zenith' of rising (setting) sun in radians (360 - 2 * 90.833 degrees)
long latitude, longitude;
long elapsedTime;//used multiple places as elapsed since midnight
long newDay;
unsigned long rise;//time in seconds from the year 2000 (GMT) for sunrise
unsigned long set;//time in seconds from the year 2000 (GMT) for sunrise
int SunriseHour, SunriseMin, SunsetHour, SunsetMin;
byte dow=0;//day of week
//END HEADER FOR MHOCKIN Weather package //
#define NUMBERS_8x16
byte vtechmode;
double MoonAge(int,int,int);
int JulianDate(int,int,int);
byte MoonState();
byte ThisPhase;
byte DayAge;
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Vortech 5
#define Heater 6
#define Refugium 7
#define UPS 8
char text[7];
byte x = 5;
byte y = 2;
byte t;
// Main Header
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, y,"Lee's Reef");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, y+9, 128, y+9);
// Param Header
y=y+20;
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,x+60, y, "PH:");
// Temp and PH
y=y+10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(128-x),y+16);
ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, x+5, y, text, Num8x16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+60, y, text, Num8x16);
y=y+20;
/// Display Sunrise / Sunset (to be calculated later...)
char riseTime[5];
char setTime[5];
char temp[]=" ";
itoa(SunriseHour,temp,10);
strcat(riseTime, temp);
strcat(riseTime, ":");
itoa(SunriseMin,temp,10);
itoa(SunsetHour,temp,10);
strcat(setTime, temp);
strcat(setTime, ":");
itoa(SunsetMin,temp,10);
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+32,y,riseTime);
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+70,y,"Set:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+98,y,setTime);
// MoonLight %
y=y+10;
t = intlength(ReefAngel.PWM.GetDaylightValue()) + 1; t *= 5;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLight:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+63, y, 1);
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x+63+t, y, "%");
// MoonPhase
y=y+10;
DayAge = MoonAge(day(), month(), year());
MoonState(DayAge);
char* ThisPhaseLabel[]={ "New","Waxing Crescent","First Quarter","Waxing Gibbous","Full","Waning Gibbous","Last Quarter","Waning Crescent" };
ReefAngel.LCD.DrawText(0,255,x,y,"Moon:");
ReefAngel.LCD.Clear(DefaultBGColor,x+32,y,x+(128-x),y+8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,x+32,y,ThisPhaseLabel[ThisPhase]);
// Vortech Mode
y=y+10;
ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
ReefAngel.LCD.Clear(DefaultBGColor,x+20,y,x+(128-x),y+8);
if (vtechmode == 0) ReefAngel.LCD.DrawText(COLOR_LIMEGREEN,255,x+20,y,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawText(COLOR_GOLD,255,x+20,y,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawText(COLOR_GOLD,255,x+20,y,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,x+20,y,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawText(COLOR_PINK,255,x+20,y,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+20,y,"Nutrient");
else if (vtechmode == 6) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+2,y,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawText(COLOR_WHITE,0,x+20,y,"Night");
// Relays
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
// Date+Time
ReefAngel.LCD.DrawDate(6, 122);
// ReefAngel.LCD. DrawGraph(5, 15);
ReefAngel.Relay.On( Vortech );
// Set Sunrise and Sunset from MHOCKIN Weather package functions.
elapsedTime=(now()-newDay); //Elapsed time is seconds from midnight of today- local processor time.
if (dow!=day()){ //used to see that were in a new day and need to recalculate sunrise and sunset
CalSun();
dow=day();
if (( hour() <= 11 ) || ( hour() >= 23 )) isNight=true; else isNight=false;
bFeeding=false;
vtechmode = 5;
if (isNight)
vtechmode = 9;
} else {
if (isNight)
} else {
int JulianDate(int d, int m, int y)
int mm, yy;
int k1, k2, k3;
int j;
yy = y - (int)((12 - m) / 10);
mm = m + 9;
if (mm >= 12)
mm = mm - 12;
k1 = (int)(365.25 * (yy + 4712));
k2 = (int)(30.6001 * mm + 0.5);
k3 = (int)((int)((yy / 100) + 49) * 0.75) - 38;
// 'j' for dates in Julian calendar:
j = k1 + k2 + d + 59;
if (j > 2299160)
// For Gregorian calendar:
j = j - k3; // 'j' is the Julian date at 12h UT (Universal Time)
return j;
double MoonAge(int d, int m, int y)
int j = JulianDate(d, m, y);
//Calculate the approximate phase of the moon
int ip = (j + 4.867) / 29.53059;
ip = ip - abs(ip);
//After several trials I've seen to add the following lines,
//which gave the result was not bad
if(ip < 0.5)
int ag = ip * 29.53059 + 29.53059 / 2;
int ag = ip * 29.53059 - 29.53059 / 2;
// Moon's age in days
byte ag = abs(ag) + 1;
return ag;
byte MoonState(byte D)
switch(D){
case 1:
0, 29;
ThisPhase = 0;
case 2:
1, 2, 3, 4, 5, 6;
ThisPhase = 1;
case 3:
7;
ThisPhase = 2;
case 4:
8, 9, 10, 11, 12, 13;
ThisPhase = 3;
case 5:
14;
ThisPhase = 4;
case 6:
15, 16, 17, 18, 19, 20, 21;
ThisPhase = 5;
case 7:
22;
ThisPhase = 6;
case 8:
23, 24, 25, 26, 27, 28;
ThisPhase = 7;
default:
return 0;
//Start of sunrise, sunset and cloud calculations- runs on reset and once a day thereafter.
void CalSun(){
latitude=dmsToSeconds(40,44,00);//United States of America- Salt Lake City, local time is -7 hours GMT
longitude=dmsToSeconds(-111,47,00);
//**********************ok now were done changing things IF YOU CHANGED the Top part of the GLOBAL variable decleration AND this... your FULLY configured and ready to load********************************************
if (dow==0){//if the controller has resarted we need to find midnight
long hours, minutes;//store current elapsed local hours as total seconds from midnight
time_t t=now();//store current clock time to parse
hours=hour(t);
hours=(hours*3600);//current hour number 0-23 as seconds
minutes=minute(t);
minutes=(minutes*60);//minutes of current hour as seconds
newDay=now();
newDay-=(hours+minutes);//Convert current local unix epoch time to local unix epoch time of midnight
else if (dow!=0){//if we did not restart but the day is new then it is midnight and were good to go..
newDay=now();
//#define SECS_YR_2000 (946684800) the time at the start of y2k (need to subtract from unix epoch time to bring to Y2K origin
newDay-=946684800;//convert GMT unix Epoch to seconds elasped since 2000 for GMT midnight of today
rise=newDay;//set value to send to SunRise as midnight GMT in seconds from Y2K
set=newDay;//
//Calculate rise time and set time using Epherma Library functions (see end of code)
SunRise(&rise);//call to Epherma function
SunSet(&set);//Call to Epherma functionunsigned long newDay;
/*Serial.print("rise and set= ");
Serial.println(rise);
Serial.println(set);
Serial.print("newDay as seconds since 2000 to todays midnight= ");
Serial.println(newDay);*/
rise=(rise-newDay);// set to elapsed seconds of day
set=(set-newDay);
/*Serial.print("rise and set as elapsed seconds of day= ");
Serial.println(set);*/
newDay+=946684800;//Convert newDay back to unix epoch GMT midnight today (used in loop to determine how far we are into the day)
/*Serial.print("newDay as seconds since since 1970 to todays midnight= ");
Serial.print("elapsed is");
long elapsed=now()-newDay;
Serial.println(elapsed);*/
SunriseHour=hour(rise);
SunriseMin=minute(rise);
SunsetHour=hour(set);
SunsetMin=minute(set);
}//END SunCalc FUNCTION
// A big thank you for these library functions. Its great!
// decimal degrees
long ddToSeconds(float dd){
return dd * 3600.0;
//Degrees, minutes, seconds
long dmsToSeconds(int d, unsigned char m, unsigned char s){
long ret;
ret = labs((long)d);
ret = ret * 3600L + 60L * m + s;
ret = (d<0L) ? -ret : ret;
return ret;
'Equation of Time'
We use the 'short form equation, which has a theoretical accuracy of about 40 seconds.
The returned value is in seconds.
int equation_of_time(unsigned long dt){
double t;
dt -= 192540UL; // refer to Jan 3 2000 05:29 (first periapsis)
dt %= _tropical_year;
t = dt;
t /= _tropical_year;
t *= 6.283185307179586;
t = -459.27672 * sin(t) + 575.333472 * sin(2.0 * t + 3.588414);
return t;
'Solar Declination'
Returns declination in radians
Accurate to within 50 arc-seconds
double SolarDeclination(unsigned long dt){
double y;
y = dt;
y /= _tropical_year; // fractional year
y *= 6.283185307179586;
y=0.006918-0.399912*cos(y)+0.070257*sin(y)-0.006758*cos(y*2)+0.000907*sin(y*2)-0.002697*cos(y*3)+0.00148*sin(y*3);
return y;
Return the period between sunrise and sunset, in seconds.
At high latitudes around the time of the solstices, this could be zero, or all day.
unsigned long daylightseconds(unsigned long dt){
float l, d, e;
long n;
d = -SolarDeclination(dt); // will be positive in Northern winter
l = latitude / _sec_rad; // latitude in radians
e += 60.0 * l * tan(l + d); // latitudinal error
d = tan(l) * tan(d); //
if(d>1.0) return 86400UL;
if(d < -1.0) return 0UL;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
Modify the passed time stamp to the time of sunrise (or sunset if 'set' is non-zero).
Returns 0 to signal 'normal' completion. If the position is in a polar circle, 1 will be
returned if the sun is above the horizon all day, and -1 if the sun is below the horizon
all day.
char SunRiseSet(unsigned long * dt, char set){
unsigned long daylen;
daylen = daylightseconds(*dt);
if(daylen == 86400UL) return 1; // there is no 'night' today (midnight sun)
if(daylen == 0UL) return -1; // there is no 'day' today
*dt /= 86400UL;
*dt *= 86400UL;
*dt += 43200UL; // set the time stamp to 12:00:00 GMT
*dt -= daylen / 2; // sunrise at the prime meridian
if(set) *dt += daylen; // sunset at the prime meridian
*dt -= equation_of_time(*dt);
//*dt -= longitude / 15.0; // rotate to our own meridian
return 0;
// 'short' forms of SunRiseSet
char SunRise(unsigned long* when){
return SunRiseSet(when, 0);
char SunSet(unsigned long* when){
return SunRiseSet(when, 1);
Ok roberto, I've made some progress. I have the custom menu cycling through my vortech modes. The only issue I have at the moment is the logic I'm doing for my scheduling...
I wanted to be able to override night mode to go into feed mode, so I've got that working, but I'd also like to be able to change the pumps if I'm in night mode as well. I've put a wrapper around the menu code so that it wouldn't change the screen if I'm set to not use memory.
Can you just look at my scheduling code and let me know if there's a better way? I should probably just simplify it since I probably shouldn't change my vortech or feed after lights out... but I want FULL control
Lee
Code is already posted in the thread below, so don't want to duplicate.
http://forum.reefangel.com/viewtopic.php?p=12941#p12941
Lee
Looks awesome!!
I think the only thing you may have problems is to come out of night mode.
Let me know if this is the case.
Got my controller,
I probably need to redo my scheduling anyway since i think the only thing synced to the GBR right now is my refugium light, vortech and moonlights
Got my controller,
Never mind, I think I got it...
What I need to do is change my vortech menu function to use SetMode instead of changing the memory value when it's not in memory mode. Then I can start the timer just like feed mode, so that I can set it to what I want and go to bed and it will revert after x time...I think that should be all I need...
And I guess then I can call StandardLights in the section of loop that decides if it's a new day so it only runs once each day when the sunrise/sunset variables change...Does that sound right?
I think at this point I've got all the feature planned except for setting up my float switches....need to figure out a bracket for my ato reservoir and DT... Thinking about aqua-hub moldable plastic strips (except for the $10 shipping for a $10 product
), but for the reservoir a magnetic might be better since I've got it in a closed container...so we'll see.
I'm having a lot of fun with this. Soo happy I got it over the apex...I know I would have felt constrained in the long run. Thanks for building a great product and for some great code!
You're right! Today was the first night I had the vortech setup and thankfully I just checked. I put it into feed mode which should trigger the function to put it back into UseMemory mode. I know I also have an issue if the controller resets during night mode as it stays in whatever active mode in memory. So I really need to restructure that part of the scheduling...rimai wrote:Looks awesome!!
Thanks, definitely in the right direction, just spinning right now trying to figure out the scheduling part without having access to my IDE at workrimai wrote:Cool!!
Yeah, I think you are in the right track.
Ok, I think I've resolved my scheduling issues... also cleaned up a lot... still waiting to hear from rufessor on the time calculations being off... but anyway, here's the current code.
Let me know if you think the scheduling and overrides look better now. I'll be testing this later tonight and my wife would appreciate if I wasn't online all night working on it...
Lee
Edit: Posted some bug fixes... Everything is working
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 8
#include <stdlib.h>
#include <math.h>
long newDay;
//*******************END HEADER FOR MHOCKIN Weather package*******************************************************
// Additional variables added for Sunrise/Sunset calculation
int UserOffset=5*3600; // 5 hours
byte vtechmode=Random2;
byte vtechDefault=Random2;
int vtechSpeed=50;
int vtechDuration=10;
byte MoonState();
byte ThisPhase;
byte DayAge;
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "Vortech Mode";
prog_char menu4_label[] PROGMEM = "ATO Clear";
prog_char menu5_label[] PROGMEM = "Overheat Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Date / Time";
prog_char menu8_label[] PROGMEM = "Version";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Vortech 5
#define Heater 6
#define Refugium 7
#define UPS 8
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
byte vtmode=vtechmode;
vtmode++;
if ( vtmode == 7 ) vtmode = 9;
if ( vtmode > 9 ) vtmode = 0;
vtechmode=vtmode;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
ReefAngel.RF.SetMode(vtmode,ReefAngel.RF.Speed,ReefAngel.RF.Duration);
ReefAngel.Timer[4].SetInterval(10); // Timer for 30min
void MenuEntry4()
ReefAngel.ATOClear();
void MenuEntry5()
ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.SetupDateTime();
void MenuEntry8()
ReefAngel.DisplayVersion();
char text[7];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Param Header
y=y+20;
// Temp and PH
y=y+10;
y=y+20; t=x;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,t,y,"Rise:"); t+=31;
itoa(SunriseHour,text,10);
if (SunriseHour<10) {
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,"0"); t+=6;
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,text); t+=6;
} else {
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,text); t+=12;
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,":"); t+=6;
if (SunriseMin<10) {
itoa(SunriseMin,text,10);
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,text); t+=20;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,t,y,"Set:"); t+=24;
itoa(SunsetHour,text,10);
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,text); t+=10;
if (SunsetMin<10) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,"0"); t+=6;
itoa(SunsetMin,text,10);
// MoonPhase
y=y+10;
MoonState(DayAge);
ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x+32,y,ThisPhaseLabel[ThisPhase]);
// MoonLight %
y=y+10;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLights:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+68, y, 1);
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x+68+t, y, "%");
// Vortech Mode
y=y+10; t=x;
ReefAngel.LCD.DrawText(0,255,x,y,"RF:"); t+=20;
ReefAngel.LCD.Clear(DefaultBGColor,t,y,x+(128-x),y+8);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,t,y,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,t,y,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,t,y,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,t,y,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,t,y,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,t,y,"Smart NTM");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,t,y,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,t,y,"Night");
// Relays
// Date+Time
// Reset Vortech to preferred defaults
InternalMemory.RFMode_write(vtechDefault);
InternalMemory.RFSpeed_write(vtechSpeed);
InternalMemory.RFDuration_write(vtechDuration);
if (dow!=day()) // used to see that were in a new day and need to recalculate sunrise and sunset
CalSun();
dow=day();
// And let's reset the light schedule
ReefAngel.StandardLights( WhiteLEDs,SunriseHour+1,SunriseMin,SunsetHour-3,SunsetMin );
ReefAngel.StandardLights( BlueLEDs,SunriseHour,SunriseMin,SunsetHour,SunsetMin );
int currTime = hour()*100+minute();
int riseTime=SunriseHour*100+SunriseMin;
int setTime=SunsetHour*100+SunsetMin;
if (( currTime <= riseTime ) || ( currTime >= setTime )) isNight=true; else isNight=false;
if (isNight)
if (ReefAngel.RF.UseMemory && ReefAngel.RF.Mode!=Night) {
} else {
// It's Daytime!
if (ReefAngel.RF.UseMemory && ReefAngel.RF.Mode==Night) {
ReefAngel.RF.SetMode(vtechDefault,15,0);
bFeeding=false;
ReefAngel.RF.SetMode(Smart_NTM,100,5);
vtechmode = Smart_NTM;
if (ReefAngel.RF.UseMemory) {
vtechmode=ReefAngel.RF.Mode;
int mm, yy;
int k1, k2, k3;
int j;
mm = m + 9;
if (mm >= 12)
mm = mm - 12;
if (j > 2299160)
return j;
ip = ip - abs(ip);
if(ip < 0.5)
return ag;
switch(D){
case 1:
0, 29;
ThisPhase = 0;
case 2:
1, 2, 3, 4, 5, 6;
ThisPhase = 1;
case 3:
7;
ThisPhase = 2;
case 4:
ThisPhase = 3;
case 5:
14;
ThisPhase = 4;
case 6:
ThisPhase = 5;
case 7:
22;
ThisPhase = 6;
case 8:
ThisPhase = 7;
default:
return 0;
void CalSun(){
// latitude=dmsToSeconds(40,44,00);//United States of America- Salt Lake City, local time is -7 hours GMT
// longitude=dmsToSeconds(-111,47,00);
latitude=dmsToSeconds(18,34,4);// Great Barrier Reef, Australia
longitude=dmsToSeconds(148,33,19); // Great Barrier Reef, Australia
hours=hour(t);
minutes=minute(t);
newDay=now();
newDay=now();
set=newDay;//
// Convert rise/set to normal hours/minutes before we make it an offset from midnight.
// Currently correcting for a 56 minute correction to Sunrise and -19 minute correction to Sunset (8/14/2012@GBR)
SunriseHour=hour(rise+(56*60)+UserOffset);
SunriseMin=minute(rise+(56*60)+UserOffset);
SunsetHour=hour(set-(19*60)+UserOffset);
SunsetMin=minute(set-(19*60)+UserOffset);
set=(set-newDay);
// decimal degrees
return dd * 3600.0;
long ret;
return ret;
'Equation of Time'
double t;
t = dt;
return t;
'Solar Declination'
double y;
y = dt;
return y;
float l, d, e;
long n;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
all day.
*dt /= 86400UL;
*dt *= 86400UL;
return 0;
Lee
Some bugfixes, slight modifications, some cleanup, and so forth...
#define CUSTOM_MENU
#include <stdlib.h>
#include <math.h>
long latitude=-18.2861; // Great Barrier Reef, Australia
long longitude=147.7000; // Great Barrier Reef, Australia
int userOffset=-(9*3600); // -9 hours
int vtechSpeed=50;
byte MoonState();
byte ThisPhase;
byte DayAge;
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Vortech 5
#define Heater 6
#define Refugium 7
#define UPS 8
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
vtmode++;
vtechmode=vtmode;
ReefAngel.Timer[4].SetInterval(1200); // Timer for 20min
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
CalSun();
void MenuEntry8()
char text[7];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Param Header
y=y+20;
// Temp and PH
y=y+10;
y=y+20; t=x;
} else {
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,text); t+=18;
if (SunsetHour<10) {
} else {
if (SunsetMin<10) { ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,"0"); t+=6; }
// MoonPhase
y=y+10;
MoonState(DayAge);
ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,ThisPhaseLabel[ThisPhase]);
// MoonLight %
y=y+10;
// Vortech Mode
y=y+10; t=x;
// Relays
// Date+Time
ReefAngel.StandardHeater( Heater,783,798 );
CalSun();
dow=day();
if (isNight)
} else {
// It's Daytime!
bFeeding=false;
ReefAngel.RF.SetMode(Smart_NTM,80,5);
ReefAngel.Timer[4].SetInterval(900); // Timer for 15min
int mm, yy;
int k1, k2, k3;
int j;
mm = m + 9;
if (mm >= 12)
mm = mm - 12;
if (j > 2299160)
return j;
ip = ip - abs(ip);
if(ip < 0.5)
return ag;
switch(D){
case 1:
0, 29;
ThisPhase = 0;
case 2:
1, 2, 3, 4, 5, 6;
ThisPhase = 1;
case 3:
7;
ThisPhase = 2;
case 4:
ThisPhase = 3;
case 5:
14;
ThisPhase = 4;
case 6:
ThisPhase = 5;
case 7:
22;
ThisPhase = 6;
case 8:
ThisPhase = 7;
default:
return 0;
void CalSun(){
long newDay;
latitude=ddToSeconds(latitude);
longitude=ddToSeconds(longitude);
hours=hour(t);
minutes=minute(t);
newDay=now();
newDay=now();
set=newDay;//
SunriseHour=hour(rise+userOffset);
SunriseMin=minute(rise+userOffset);
SunsetHour=hour(set+userOffset);
SunsetMin=minute(set+userOffset);
// decimal degrees
return dd * 3600.0;
long ret;
return ret;
'Equation of Time'
double t;
t = dt;
return t;
'Solar Declination'
double y;
y = dt;
return y;
float l, d, e;
long n;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
all day.
*dt /= 86400UL;
*dt *= 86400UL;
return 0;
Latest version... bugs fixed in Sunrise/Sunset. Still have some issues with Vortech controlling in feeding mode, etc. It doesn't change the DISPLAY_MODE when I go into feeding mode from my iphone app... and so the vortech never changes mode...but my skimmer goes off... not sure what's going on yet... Also need to try and use ONLY memory through the various modes because that's the only way I can easily change it from other places...
// By Matthew Hockin 2012.
// SWFLTEK library functions, #includes, and #define were copied directly from the Epherma library
// Epherma (SWFLTEK.com) was written by Michael Rice - thanks Michael it works great.
// If you copy from this (its all open source) please acknowledge Michael for SWFLTEK library
// code (obviously labeled) and Matthew Hockin (for the rest).
#define CUSTOM_MENU
#include <stdlib.h>
#include <math.h>
//variables for SWFLTEK functions
byte SunriseHour, SunriseMin, SunsetHour, SunsetMin;
byte dom=0;//day of month
int userRiseOffset=-(9*3600)+472;
int userSetOffset=-(9*3600)+506;
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//Vortech Mode Definitions
byte vtechmode=Smart_TSM;
byte vtechDefault=Smart_TSM;
byte vtechDuration=10;
byte vtechSpeed=40;
byte vtechNTMSpeed=65;
byte vtechNightSpeed=10;
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define UPS 5
#define Heater 6
#define Refugium 7
#define Vortech 8
// Custom Menu Code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
vtmode++;
vtechmode=vtmode;
ReefAngel.RF.SetMode(vtmode,40,10);
ReefAngel.Timer[1].SetInterval(1200); // Timer for 20min
ReefAngel.Timer[1].Start();
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
// Custom Main Screen
char text[7];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Param Header
y=y+20;
// Temp and PH
y=y+10;
y=y+20; t=x;
} else {
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,text); t+=14;
} else {
// MoonPhase
y=y+10;
ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,MoonPhaseLabel());
// MoonLight %
y=y+10;
// Vortech Mode
y=y+10; t=x;
// Relays
// Date+Time
// Setup on controller startup/reset
// Initialize Menu
ReefAngel.FeedingModePorts = Port2Bit;
// Convert lat/long to proper format
ReefAngel.Relay.DelayedOn( Skimmer, 15 );
ReefAngel.StandardHeater( Heater,783,788 );
if (dom!=day()) // used to see that were in a new day and need to recalculate sunrise and sunset
CalSun();
dom=day();
// Send the date/time to the portal...
ReefAngel.CustomVar[0]=SunriseHour;
ReefAngel.CustomVar[1]=SunriseMin;
ReefAngel.CustomVar[2]=SunsetHour;
ReefAngel.CustomVar[3]=SunsetMin;
ReefAngel.StandardLights( WhiteLEDs,SunriseHour+1,SunriseMin,SunsetHour-3, SunsetMin );
// Let's make the time one number so we can figure out it's night or day...
if (isNight)
ReefAngel.RF.SetMode(Night,vtechNightSpeed,0);
} else {
// It's Daytime!
ReefAngel.RF.SetMode(vtechDefault,vtechNightSpeed,0);
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.Relay.On( Refugium );
bFeeding=false;
ReefAngel.RF.SetMode(Smart_NTM,vtechNTMSpeed,5);
ReefAngel.Timer[1].SetInterval(45*60); // Timer for 45 minutes
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[1].IsTriggered())
// Start of sunrise, sunset and cloud calculations- runs on reset and once a day thereafter.
void CalSun(){
long hours, minutes, seconds;//store current elapsed local hours as total seconds from midnight
long newDay;
time_t t=now(); //store current clock time to parse
hours=hour(t);
hours=(hours*3600); //current hour number 0-23 as seconds
minutes=minute(t);
minutes=(minutes*60); //minutes of current hour as seconds
seconds=second(t);
newDay=now();
newDay-=(hours+minutes+seconds); //Convert current local unix epoch time to local unix epoch time of midnight
newDay-=SECS_YR_2000; // Convert GMT unix Epoch to seconds elasped since 2000 for GMT midnight of today (+946684800)
rise=newDay;
set=newDay;
// Calculate rise time and set time using Epherma Library functions (see end of code)
SunRise(&rise);
SunSet(&set);
// Bring us back to real time.
rise+=SECS_YR_2000;
set+=SECS_YR_2000;
newDay+=SECS_YR_2000;
// Set the invididual variables and add userOffsets.
SunriseHour=hour(rise+userRiseOffset);
SunriseMin=minute(rise+userRiseOffset);
SunsetHour=hour(set+userSetOffset);
SunsetMin=minute(set+userSetOffset);
// The code below this is copied directly from the SWFLTEK Epherma library constructed by Michael Rice.
// This code is being used freely with attribution to Micahel Rice in accord with his request
// decimal degrees
return dd * 3600.0;
// Degrees, minutes, seconds
long dmsToSeconds(int d, unsigned char m, unsigned char s) {
long ret;
return ret;
'Equation of Time'
int equation_of_time(unsigned long dt) {
double t;
t = dt;
return t;
'Solar Declination'
double SolarDeclination(unsigned long dt) {
double y;
y = dt;
return y;
unsigned long daylightseconds(unsigned long dt) {
float l, d, e;
long n;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
all day.
*dt /= 86400UL;
*dt *= 86400UL;
return 0;
OK. Finally after an almost all nighter of attempting to fix some bugs. I've converted all the operations in the RF mode to use InternalMemory. This means that I can change from portal, iPhone (if it didn't crash when I try to save the memory..) or from the Menu. I have full control from the menu with custom durations and speeds for each mode. I'm also displaying the speed/duration on the main screen as well. All the Sunrise/Sunset code is working good. No more issues there. Only thing long term left is to get more temp probes and hook up the float switches
The only outstanding issues are that when in night mode, it does not kick out to feeding mode. Also, sometimes when going into feeding mode, the LCD does not clear completely even though i added a flag to return and clearscreen in my CustomMain. Would love some thoughts on these two issues. In the meantime... here's the current code.
#define CUSTOM_MENU
// Custom Menu Code
#include <stdlib.h>
#include <math.h>
// Vortech Defaults
byte vtMode=Random2;
byte vtSpeed=45;
byte vtDuration=5;
byte vtNTMSpeed=65;
byte vtNTMDuration=5;
byte vtNightSpeed=10;
byte vtNightDuration=20;
byte vtPrevMode;
byte vtPrevSpeed;
byte vtPrevDuration;
boolean isFeeding=false;
boolean vtOverride=false;
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define UPS 5
#define Heater 6
#define Refugium 7
#define Vortech 8
// Initialize Menu
vtPrevMode=InternalMemory.RFMode_read();
vtPrevSpeed=InternalMemory.RFSpeed_read();
vtPrevDuration=InternalMemory.RFDuration_read();
ReefAngel.Relay.DelayedOn( Skimmer, 20 );
ReefAngel.StandardHeater( Heater,778,782 );
if (dom!=day()) // Used to see that were in a new day and need to recalculate sunrise and sunset
CalSun();
dom=day();
if ( (currTime <= riseTime) || (currTime >= setTime) ) isNight=true; else isNight=false;
if (isNight)
if (vtOverride==false && isFeeding==false) {
setRFmode(Night,vtNightSpeed,vtNightDuration);
} else {
// It's Daytime!
if (vtOverride==false && vtMode==Night) {
setRFmode(vtPrevMode,vtPrevSpeed,vtPrevDuration);
if (ReefAngel.DisplayedMenu==FEEDING_MODE) isFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && isFeeding )
isFeeding=false;
setRFmode(Smart_NTM,vtNTMSpeed,vtNTMDuration);
if (vtOverride && ReefAngel.Timer[1].IsTriggered())
vtOverride=false;
} else {
setRFmode(); // Update if set externally
// Vortech Helper functions
void setRFmode(int mode, int speed, int duration) {
// Check if mode has changed
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
if (mode!=InternalMemory.RFMode_read()) {
InternalMemory.RFMode_write(mode);
// Temp fix for coming out of night mode
if (vtPrevMode==Night) {
if (isNight || vtMode==Smart_NTM) {
setRFtimer(30);
// Check if speed has changed
if (speed!=vtSpeed) {
vtPrevSpeed=vtSpeed;
vtSpeed=speed;
if (speed!=InternalMemory.RFSpeed_read()) {
InternalMemory.RFSpeed_write(speed);
// Check if duration has changed
if (duration!=vtDuration) {
vtPrevDuration=vtDuration;
vtDuration=duration;
void setRFmode() {
setRFmode(InternalMemory.RFMode_read(), InternalMemory.RFSpeed_read(), InternalMemory.RFDuration_read());
void setRFtimer(int minutes) {
ReefAngel.Timer[1].SetInterval(minutes*60);
vtOverride=true;
// Menu Code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
byte mode, speed,duration;
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
speed=50; duration=0; // Constant
} else if (mode == 1) {
speed=40; duration=0; // Lagoon
} else if (mode == 2) {
speed=45; duration=0; // Reef Crest
} else if (mode == 3) {
speed=50; duration=10; // Short Pulse
} else if (mode == 4) {
speed=50; duration=20; // Long Pulse
} else if (mode == 6) {
speed=45; duration=10; // Smart_TSM
} else if (mode == 5) {
speed=vtNTMSpeed; duration=vtNTMDuration; // Smart_NTM
} else if (mode == 7) {
speed=vtNightSpeed; duration=vtNightDuration; // Night
mode=9;
setRFmode(mode,speed,duration);
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
char text[7];
byte x = 5;
byte y = 2;
byte t;
if (isFeeding) { ReefAngel.ClearScreen(DefaultBGColor); return; }
// Main Header
// Param Header
y+=20;
// Temp and PH
y+=10;
y+=20; t=x;
} else {
} else {
// MoonPhase
y+=10;
// MoonLight %
y+=10;
// Vortech Mode
y+=10; t=x;
if (vtMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,t,y,"Constant");
else if(vtMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,t,y,"Lagoon");
else if (vtMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,t,y,"Reef Crest");
else if (vtMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,t,y,"Short Pulse");
else if (vtMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,t,y,"Long Pulse");
else if (vtMode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,t,y,"Smart NTM");
else if (vtMode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,t,y,"Tidal Swell");
else if (vtMode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,t,y,"Night");
y+=10; t=x;
ReefAngel.LCD.DrawText(0,255,x,y,"RF Speed:"); t+=60;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,t,y,InternalMemory.RFSpeed_read()); t+=15;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,t,y,"/"); t+=10;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,t,y,InternalMemory.RFDuration_read());
// Relays
// Date+Time
void CalSun(){
long newDay;
hours=hour(t);
minutes=minute(t);
seconds=second(t);
newDay=now();
rise=newDay;
set=newDay;
SunRise(&rise);
SunSet(&set);
rise+=SECS_YR_2000;
set+=SECS_YR_2000;
// decimal degrees
return dd * 3600.0;
long ret;
return ret;
'Equation of Time'
double t;
t = dt;
return t;
'Solar Declination'
double y;
y = dt;
return y;
float l, d, e;
long n;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
all day.
*dt /= 86400UL;
*dt *= 86400UL;
return 0;
Ok. I created a ticket.
https://github.com/reefangel/Libraries/issues/46
Ok, have some bug fixes and some cleanup. My Vortech's were going in and out of night mode all night because of how I was setting the timer. I hope this resolves it. I also implemented the SunLocation class that binder put together from the code I scraped together. Deails on that class are located on this post (with fixes) http://forum.reefangel.com/viewtopic.php?p=14508#p14508
I have one issue still.. I'm trying to add a menu option to toggle the refugium light.. not working as I'd hope. If there is a simple way to do it, I'd be grateful
Thanks and Enjoy
Thanks and Enjoy
#include <SunLocation.h>
#define CUSTOM_MENU
// Custom Menu Code
prog_char menu4_label[] PROGMEM = "Refugium Light";
prog_char menu5_label[] PROGMEM = "ATO Clear";
// Vortech Defaults
byte vtSpeed=45;
byte vtDuration=5;
byte vtNTMSpeed=65;
byte vtPrevMode;
byte vtPrevSpeed;
SunLocation sl;
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define UPS 5
#define Heater 6
#define Refugium 7
#define Vortech 8
// Initialize Menu
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit;
// Setup SunLocation class
sl.Init(-18.285833, 147.699722);
sl.SetOffset(-9,472,-9,506);
// Save previous used vortech mode.
sl.CheckAndUpdate();
SunriseHour=sl.GetRiseHour(); SunriseMin=sl.GetRiseMinute();
SunsetHour=sl.GetSetHour(); SunsetMin=sl.GetSetMinute();
// Send the SunLocation info to the portal
ReefAngel.CustomVar[0]=SunriseHour; ReefAngel.CustomVar[1]=SunriseMin;
ReefAngel.CustomVar[2]=SunsetHour; ReefAngel.CustomVar[3]=SunsetMin;
// Turn the lights on
if (isNight)
} else {
// It's Daytime!
isFeeding=false;
vtOverride=false;
} else {
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
if ( (isNight && vtMode != Night) || vtMode==Smart_NTM) {
setRFtimer(30);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
mode=9;
void MenuEntry4()
ReefAngel.Relay.Toggle ( Refugium );
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Param Header
y+=18;
// Temp and PH
y+=8;
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+60, y, buf, Num8x16);
y+=20; t=x;
sprintf(buf, "%02d:%02d", SunriseHour, SunriseMin);
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,buf);
sprintf(buf, "%02d:%02d", SunsetHour, SunsetMin); t+=36;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,t,y,"Set:"); t+=25;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
// Relays
// Date+Time
Can you help me replicate this issue?lnevo wrote:Also, sometimes when going into feeding mode, the LCD does not clear completely even though i added a flag to return and clearscreen in my CustomMain.
I was unable to do so...
I'd like to fix in the libraries, but I can't get it to do that.
I'll take a few more peaks the next few feedings and see if I'm still experiencing it. If you have any troubleshooting you'd like me to try... You could also run my code (but now you'll need the SunLocation class
) as a test...if I'm just crazy...
Modified my code to use heater temp settings from memory so I can modify without changing code. I also added a function to the SunLocation class so I can have my lighting times controlled by memory. I'll be posting that separately. I also added my float switches and set the Low to turn off my pump / skimmer when the water level in the return chamber gets too low (drain problem, ato problem?). The high I am using to send me an alert if something happens and the sump gets too full (return pump issue, return line obstruction...) Next up waiting for my water level sensor and I'll be able to monitor my ATO reservoir.
Edit: Needed to add a flag instead of just checking the mode, otherwise it would never turn return pumps back on after water change / feeding mode... The flag is used if triggered, mode change, or controller restart and is reset once the HighATO.IsActive function comes up false. This way it's only disabled once and not when we trigger it on purpose.
Here's the code.
Here's the code.
#define CUSTOM_MENU
// Custom Menu Code
// Vortech Defaults
byte vtPrevMode=0;
byte vtPrevSpeed=0;
byte vtPrevDuration=0;
byte vtSpeed=45;
byte vtDuration=5;
byte vtNTMSpeed=55;
boolean activatedHighATO=true;
SunLocation sl;
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define UPS 5
#define Heater 6
#define Refugium 7
#define Vortech 8
// Initialize Menu
sl.Init(-18.285833, 147.699722); // GBR
sl.SetOffset(-9,472,-9,506); // 9 hour difference
ReefAngel.Relay.DelayedOn( Skimmer, 5 );
ReefAngel.StandardHeater( Heater );
// Turn on the lights
ReefAngel.StandardLights( WhiteLEDs );
ReefAngel.ActinicLights( BlueLEDs );
int currTime=NumMins(hour(),minute());
int riseTime=NumMins(sl.GetRiseHour(),sl.GetRiseMinute());
int setTime=NumMins(sl.GetSetHour(),sl.GetSetMinute());
if (isNight)
// Trigger night mode again to extend built-in timer
if ( ((hour() == 6) && (minute() == 00) && (second() == 00) ) ) {
} else {
// It's Daytime!
ReefAngel.Timer[1].ForceTrigger();
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) activatedHighATO=true;
isFeeding=false;
else if (vtOverride && ReefAngel.Timer[1].IsTriggered())
vtOverride=false;
if ( ((hour() == 15) && (minute() == 00) && (second() == 00) ) ) {
if (ReefAngel.LowATO.IsActive()) {
bitClear(ReefAngel.Relay.RelayMaskOff,Return-1);
bitClear(ReefAngel.Relay.RelayMaskOff,Skimmer-1);
if (!activatedHighATO) {
ReefAngel.CustomVar[0]=2;
} else {
ReefAngel.CustomVar[0]=1;
activatedHighATO=false;
// Turn off Skimmer if Return pump is shutoff.
if (bitRead(ReefAngel.Relay.RelayMaskOff,Return-1)==0) {
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
setRFtimer(30);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
byte mode,speed,duration,prev_mode,prev_speed,prev_dur;
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
mode=9;
prev_mode=vtPrevMode; prev_speed=vtPrevSpeed; prev_dur=vtPrevDuration;
if (!isNight) {
vtPrevMode=prev_mode; vtPrevSpeed=prev_speed; vtPrevDuration=prev_dur;
void MenuEntry4()
if (isNight) {
if (bitRead(ReefAngel.Relay.RelayMaskOff,Refugium-1)==1) {
bitClear(ReefAngel.Relay.RelayMaskOff,Refugium-1);
} else {
bitSet(ReefAngel.Relay.RelayMaskOff,Refugium-1);
} else {
if (bitRead(ReefAngel.Relay.RelayMaskOn,Refugium-1)==1) {
bitClear(ReefAngel.Relay.RelayMaskOn,Refugium-1);
} else {
bitSet(ReefAngel.Relay.RelayMaskOn,Refugium-1);
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Param Header
y+=18;
// Temp and PH
y+=8;
y+=20; t=x;
sprintf(buf, "%02d:%02d", sl.GetRiseHour(), sl.GetRiseMinute());
sprintf(buf, "%02d:%02d", sl.GetSetHour(), sl.GetSetMinute()); t+=36;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
// Relays
// Date+Time
Added my relay expansion yesterday. Lot's of new additions to the code. The following features have been added:
Vacation Mode - Use WL sensor and turn the extension cord I have plugged in, into an ATO port
ATO Refill - Use WL sensor to fill my ATO reservoir to 100%
Power Outage detection - Turn off all unnecessary items if we lose power.
Complete Darkness - Added 2 hours without moonlghts to my schedule
Smart_NTM Delay - Added a delay after feeding mode before Smart_NTM is activated
Dosing Pumps - Added these, but I need to get better pumps
Coral Acclimation Schedule - Need to test this, but should be working good.
#define CUSTOM_MENU
// Custom Menu Code
prog_char menu5_label[] PROGMEM = "Clear Overrides";
prog_char menu7_label[] PROGMEM = "WLS Calibration";
prog_char menu8_label[] PROGMEM = "Date / Time";
prog_char menu9_label[] PROGMEM = "Version";
menu7_label, menu8_label, menu9_label
// Vortech Defaults
byte vtPrevMode=0;
byte vtPrevSpeed=0;
byte vtSpeed=45;
byte vtDuration=5;
byte vtNTMSpeed=65;
byte vtNightSpeed=20;
byte vtNightDuration=10;
boolean feedDelay=false;
boolean floatHigh=true;
boolean powerOutage=true;
int riseOffset=472;
int setOffset=506;
byte acclTime=0;
SunLocation sl;
//Define Custom Memory Location
#define Mem_B_RefillATO 100
#define Mem_B_Vacation 101
#define Mem_B_AcclTime 102
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Extension 5
#define Heater 6
#define Refugium 7
#define Reactor 8
#define Unused1 Box1_Port1
#define Unused2 Box1_Port2
#define Vortech1 Box1_Port3
#define Vortech2 Box1_Port4
#define VortechUPS Box1_Port5
#define Unused3 Box1_Port6
#define DPump1 Box1_Port7
#define DPump2 Box1_Port8
// Initialize Menu
ReefAngel.Relay.On( Vortech1 );
ReefAngel.Relay.On( Vortech2 );
ReefAngel.Relay.On( VortechUPS );
ReefAngel.Relay.Off( Extension );
ReefAngel.Relay.Off( Unused1 );
ReefAngel.Relay.Off( Unused2 );
ReefAngel.Relay.Off( Unused3 );
ReefAngel.CustomVar[7]=255;
ReefAngel.DosingPumpRepeat1( DPump1 );
ReefAngel.DosingPumpRepeat2( DPump2 );
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
powerOutage=false;
LastStart=now();
ReefAngel.CustomVar[1]=0;
ReefAngel.Relay.DelayedOn( Reactor, 10 );
if (InternalMemory.read( Mem_B_Vacation )==1) {
ReefAngel.WaterLevelATO( Extension,30,61,63 );
ReefAngel.CustomVar[3]=1;
} else {
ReefAngel.CustomVar[3]=0;
if (InternalMemory.read( Mem_B_RefillATO )==1) {
if (ReefAngel.WaterLevel.GetLevel()<=100) {
ReefAngel.Relay.On( Extension );
ReefAngel.CustomVar[2]=1;
} else {
InternalMemory.write( Mem_B_RefillATO, 0);
ReefAngel.CustomVar[2]=0;
acclTime=InternalMemory.read( Mem_B_AcclTime );
if (acclTime > 0) {
ReefAngel.CustomVar[4]=acclTime;
if ( (hour()==0) && (minute()==0) && (second()==0)) {
acclTime--;
InternalMemory.write( Mem_B_AcclTime, acclTime );
sl.SetOffset(-9,riseOffset+(acclTime*240),-9,setOffset+(acclTime*120)); // 9 hour difference
if (isNight)
if ((hour()>=3) && (hour()<=5)) {
} else {
} else {
// It's Daytime!
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) floatHigh=true;
isFeeding=false;
feedDelay=true;
setRFtimer(30); // Stay in FeedMode for a while longer.
vtOverride=false;
if(feedDelay) {
feedDelay=false;
} else {
if (!floatHigh) {
floatHigh=true;
} else {
ReefAngel.CustomVar[0]=0;
floatHigh=false;
// Power Outage - Only Return Pump
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Exp1 Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off (Skimmer);
ReefAngel.Relay.Off (WhiteLEDs);
ReefAngel.Relay.Off (BlueLEDs);
ReefAngel.Relay.Off (Extension);
ReefAngel.Relay.Off (Heater);
ReefAngel.Relay.Off (Refugium);
ReefAngel.Relay.Off (Reactor);
ReefAngel.CustomVar[1]=1;
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
setRFtimer(60);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
speed=55; duration=10; // Short Pulse
speed=55; duration=20; // Long Pulse
speed=50; duration=10; // Smart_TSM
mode=9;
if (!isNight) {
void MenuEntry4()
if (isNight) {
} else {
} else {
} else {
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry8()
void MenuEntry9()
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// if (isFeeding) { ReefAngel.ClearScreen(DefaultBGColor); return; }
// Main Header
// ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, y,"Lee's Reef");
// Date+Time
ReefAngel.LCD.DrawDate(x+1, y);
// Param Header
y+=12;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=2;
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
y+=6;
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
y+=15; t=x;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
// Display Water level
y+=10; t=x;
ConvertNumToString(buf, ReefAngel.WaterLevel.GetLevel(), 1);
strcat(buf," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"AT0 Level:"); t+=60;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,t,y,buf);
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
y+=15;
// Relays
ReefAngel.LCD.DrawOutletBox(12, y, TempRelay);
y+=12;
Bugs worked out with Coral Acclimation counter and a lot of comments / code cleanup
//#include <Salinity.h>
//#include <IO.h>
//#include <ORP.h>
//#include <AI.h>
#define CUSTOM_MENU
// Custom Menu Code
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "WLS Calibration";
prog_char menu9_label[] PROGMEM = "Date / Time";
// Vortech Defaults
byte vtPrevMode=0;
byte vtPrevSpeed=0;
// Default Mode
byte vtSpeed=45;
byte vtDuration=5;
// NTM mode
byte vtNTMSpeed=65;
// Night Mode
byte acclTime=0;
SunLocation sl;
#define Mem_B_ClearATO 103
//Define Relay Ports by Name
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Extension 5
#define Heater 6
#define Refugium 7
#define Reactor 8
// Initialize Menu
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit ;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port6Bit;
// Ports that default on
// Ports that default off
sl.Init(-18.285833, 147.699722); // Great Barrier Reef
// What was our previous modes before we restarted?
// Default port modes. Use Memory settings for external control
// See if power is back on so DelayedOn ports will reset.
powerOutage=false;
LastStart=now();
ReefAngel.Relay.DelayedOn( Skimmer );
ReefAngel.Relay.DelayedOn( Reactor );
// We're on vacation! Use external pump to top off the top off.
} else {
// Real ATO Clear
if (InternalMemory.read( Mem_B_ClearATO )==1) {
// ATO Refill mode. Top off ATO reservoir until it's at 100%
} else {
// See if we are acclimating corals and decrement the countdown each night
static boolean acclCounterReady=false;
if ( acclCounterReady && now()%86400==0) {
acclTime--;
if ( now()%86400!=0 ) acclCounterReady=true;
// -9 hour difference for time zone. 472/506 seconds were calculation corrections
// The acclTime will adjust the sunrise/sunset if we are adjusting for new coral
sl.SetOffset(-9,472+(acclTime*240),-9,506-(acclTime*120));
// Calculate the new Sunrise / Sunset based on our GPS coordinates
if (isNight)
// Some complete darkness
} else {
// Set moonlights to the MoonPhase
// Vortech's to night mode.
// Turn on refugium light opposite normal lights
} else { // It's Daytime!
// Regular lights are controlled by Memory variables set in SunLocation class
// Go back to our regularly scheduled program.
// Force the trigger to make sure we break feeding/night modes.
// Enable Feeding Mode flag
// Turn on Refugium light during water change mode
// Enable ATOHigh flag on purpose during feed/water change mode so we don't get alerts.
/*** RF Modes ***/
// Here's what we do if we're just out of feeding mode...
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && isFeeding ) {
isFeeding=false;
feedDelay=true; // This will let us know we want some extra time before Smart_NTM
setRFtimer(30); // Start Smart_NTM in 30 minutes...
} else if (vtOverride && ReefAngel.Timer[1].IsTriggered()) { // Our RF timer is over.
vtOverride=false; // Stop overriding the default RF mode
// First let's deal with that extra 30 minutes
if(feedDelay) {
feedDelay=false; // Reset the feedDelay flag
setRFmode(Smart_NTM,vtNTMSpeed,vtNTMDuration); // Smart_NTM time!
} else {
// Otherwise go to Previous settings
} else {
setRFmode(); // Update the mode if we change it remotely
// A little extra Smart_NTM never hurt anyone
/*** End of RF modes ***/
// Turn off return pump if we run out of water!
// Turn off return if we are somehow overflowing the sump
if (!floatHigh) {
floatHigh=true;
} else {
floatHigh=false;
// Power Outage - Only Return Pump should be active
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
powerOutage=true;
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
// Fix for coming out of night mode
// If it's at night or we are setting NTM, do this only temporarily
setRFtimer(60);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1() {
void MenuEntry2() {
void MenuEntry3() {
byte mode,speed,duration;
byte prev_mode,prev_speed,prev_dur;
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
mode=9;
// If it's night time, don't overwrite the default daytime mode when using the menu
if (!isNight) {
void MenuEntry4() {
if (isNight) { // Turn off the Refugium light
} else {
} else { // Turn on the Refugium light
} else {
void MenuEntry5() {
void MenuEntry6() {
void MenuEntry7() {
void MenuEntry8() {
void MenuEntry9() {
void DrawCustomMain() {
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Date+Time
// Param Header
y+=12;
// Temp and PH
y+=2;
y+=6;
y+=5;
y+=15; t=x;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
y+=10; t=x;
strcat(buf," ");
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
y+=15;
// Relays
y+=12;
void DrawCustomGraph() {
Got my controller,
Ok, figured out what happened. I overwrote the code that reads the timer from memory and updates my CustomVar when I pasted roberto's timer change. So acclTime reverted to 0 and memory was written as 255. Portal showed 0 since I was no longer updating that variable. I will post my fixes and final code tonight.
