Here is a similar code used on the PWM expansion module, except this one is made for the standard channels.
Attached is a demo PDE to be used.
Try it out and let me know if it works. I'd love to see a video.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
