New Windows Gadget
dedvalson
Re: New Windows Gadget
Hi,
I hope no one minds, but I have attached an updated version of the Gadget with the following changes.
1. The main window is 30 pixels taller so that the arrow is visible (at least on my screen).
2. The Flyout 2 window is also taller so that all the LEDs are visible.
3. I changed R0 to R1.
4. I bumped the revison to 1.0.1.0
Don
Don
- Contact:
Ademster
Do I have to add some sort of code?
I am not able to get this to work.
Adam
58 Gal
58 Gal
I'm assuming you have the wifi attachment working, right?
Then, on Reefangel IP address, you have to make sure you add http:// in front of it and :2000 after it.
Like this: http://ipaddress:2000
Ademster
Portal works, Android app works,
but not the windows gadget.
using same address
using same address
Adam
58 Gal
58 Gal
Can you browse to your controller when you type http://ipaddress:2000 in your browser address?
You should see "Reef Angel Controller Web Server"
Copy the address that your browser is showing and paste it in the gadget address
Ademster
I get the Reef Angel controller web server,
still nothing on the widget.
Adam
58 Gal
58 Gal
Weird.
Are you using the version posted on this page?
Here is how mine looks.
Piper
I was having the same issues at first. Make sure you don't have the trailing slash at the end of your URL: http://ipaddress:2000
It took a a few seconds, maybe a minute, after dropping the trailing slash for it to start registering.
~Charlie
~Charlie
Ademster
I had to delete the gadget completely, reinstall it, then delete it again. reinstall ( fresh download ) and it worked finally!
Adam
58 Gal
58 Gal
modulok
Anyone else having problems with the wifi attachment while using the gadget 24/7? It seemed to have started after I updated the RA library.
My wifi attachment will stop updating, but will reply to ping. I have to manually reconnect the wire and it will work for maybe a day or two.
I turned off the gadget and my wifi has been working for weeks without issue.
jjdezek
tried this gadget also cant get it to load. how long does it take to work, instant or a few mins? also i have 2 different ip addresses, i have my network ip then i have the RA ip which one do i use?
- Sacohen
It takes some time. I walked away from my computer and came back sometime later and it was working.
pragyaware
very Good Thread. Yet i have no interest in Develop but i like your gadgets and there themes very much.
- maineultraclassic
Any way to get Salinity added to the gadget?
54gal Corner Bowfront with 30gal basement sump
- Sacohen
I don't think the creator is really working on this anymore. I haven't seen an update in a while. As you cab see there hasn't been a post since last year.
