Portal isn't updating for me today...
Not sure why, but the Portal page isn't updating nor loading for me today at all.
My Android app is working fine and is getting data just fine, but the portal shows
Last Update: Never
Displaying data from: "Unavailable".
My sig picture shows it was last updated on 8/14/2012 7:26:47 AM... so it was working fine until yesterday morning.
Today, I've tried using the actual IP address and also switched to the dynamic dns website name... neither seems to be working. My android app is setup using xxxxxxxx.dyndns.xxx:2000.
Anyway, if anyone can help that would be appreciated.
Last Update: Never
Re: Portal isn't updating for me today...
can you connect to the controller with your phone?
Yes. Everything displays correctly on the phone and i can make changes with the app too.
Portal just doesn't seem to want to connect.
Sent from my DROID RAZR using Tapatalk 2
Are you sure you didn't change anything in the portal, like security key?
Have you uploaded a new code to the controller around that time?
Sorry I didn't reply back right away Roberto... been a lil busy with other things in life and didn't get a chance to come back here.
I haven't done anything with security key nor did I upload new code (except for the attempts at loading the weather sim code to the dimming module, but that was on Saturday the 11th... and I switched it all back to the default when it didn't work for me.)
Anyway, I just tried the portal page again before the reply and it connected fine. Not sure why it wasn't working before because I haven't done anything to my controller since my last post on wednesday. It just magically worked today, lol. My signature monitor has still been saying the "last update" was 8/14/12 until just now.
EDIT the signature monitor still shows last update at 8/14/12, but I just manually updated/refreshed the portal page a minute ago and it seems to be working.
OK, the web banner in my sig seems to be updating correctly now too. Not sure how this got broken or how it got fixed, but all is good now.
Well, correction... the Portal is still working fine, but the web banner isn't updating for me now.
I'm puzzled since I haven't changed anything throughout all of this.
I think it may be the timeouts I've been seeing lately, but they usually don't last that long and the controller eventually sends data.
I changed something on the ext release, but if you would like to try in advance, take a look at this post:
http://forum.reefangel.com/viewtopic.php?p=13102#p13102
Thanks for the quick reply as usual Roberto!
The "fix" you have in that link appears to need me to re-upload code to my controller... which I'm too tired to do right now.
I'm going on vacation on Saturday morning, so hopefully I'll get a chance to test the fix before then.
Just following up on this. I added the fix Roberto suggested and it seemed to work for a while. It didn't update as often as I'd like, but it was at least once per day for a while.
As of right now, Portal isn't updating for me at all since 10/8/2012 @ 7:59:34 AM (EST).
When I go to the Portal page now, it just says:
I've tried using my current external IP address as well as the dyn.dns one that has worked in the past and is currently working for the Android App right now... but not working for the Portal.
WiFi attachment is blinking Green as normal and Android App works like a charm with everything I try. Portal just won't connect?
and never updates.Reef Angel wifi address: xxxxxxx.dyndns.info:2000 (update)
My reefangelid: TanksNStuff
Connection Status:
Last Update: Never
Displaying data from: Unavailable
Can you browse http://xxxx.dyndns.info:2000 ??
If you can, the portal should too.
I can, but this is all the page shows:
Reef Angel Controller Web Server (in large font).
What is the command to view the data? /r ?
No, I've never used tera term or putty
/r99 gives me the following output:
- <RA>
<T1>766</T1>
<T2>768</T2>
<T3>703</T3>
<PH>817</PH>
<R>244</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>79</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>3</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<PWME0>92</PWME0>
<PWME1>92</PWME1>
<PWME2>66</PWME2>
<PWME3>66</PWME3>
<PWME4>0</PWME4>
<PWME5>0</PWME5>
<RFM>0</RFM>
<RFS>100</RFS>
<RFD>20</RFD>
<RFW>0</RFW>
<RFRB>0</RFRB>
<RFR>0</RFR>
<RFG>0</RFG>
<RFB>0</RFB>
<RFI>0</RFI>
</RA>
I get the same output when using my external ip address with :2000/r99 also.
Seems like the data is being sent, but Portal is not updating.
I'm curious to know what you have in your settings.
Can you download putty and connect to the wifi attachment through serial at 57600 baud?
To enter command mode, you need to type $$$ within half a second. The module should respond with CMD.
Then, send this command:
get c
It should return with some settings.
Copy and paste here
get c
Copy and paste here
I just downloaded Putty, but not quite sure how to use it yet. Can it be used remotely? I'm at work right now.
If I go to the serial connection page, it only asks for a COM port and speed, etc. Nothing to add an IP address to connect remotely.
Do I need to do it through the proxy connection? Sorry for my ignorance, I'm just not familiar with this prog yet.
OK, I'll do this tonight when I get home then.
For what it's worth, I tried connecting to the IP/port via Telnet and entered $$$ as the window popped up.
It gave me this:
Is that what you're looking for?
It gave me this:
CMD
<2.23> get c
get c
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
<2.23>
yes, that's what I wanted to see.
Can you do the same thing bu with "get e". This will dump all settings.
CMD
<2.23> get e
get e
WiFly Ver 2.23, 04-26-2011 on 131C11
Beacon=100
Probe=5
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
IF=UP
DHCP=ON
IP=192.168.1.117:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
BACKUP=0.0.0.0
DNS=75.75.75.75
Name=www.reefangel.com
Backup=backup2
FTP=208.109.14.133:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=40
FTP_mode=0x0
SSID=xxxxxxxx <~~~~~ Changed for privacy
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=xxxxxxxx <~~~~~ Changed for privacy
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
PrintLvl=0x0
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Sensor=0x0
SensePwr=0x0
<2.23>
yeah, everything looks good.
Not sure why it is not connecting.
Hmm, OK.
Is it preferred to use the external IP address or the dyndns.info for the portal? I know either will probably work, but which is more "failsafe" to use?
The portal automatically changes it to the latest ip address when it receives data, so no matter what you put in, eventually it gets changed by the Portal anyway.
But if it doesn't receive data, it has no way of telling which ip address you are sending it from.
I think that might be the issue then. Any way to "push" the data to the Portal manually so that it gets a latest IP address?
What if I tried removing all the portal info from my profile and saving, then re-entering it from scratch?
No, it has to do with the controller not communicating with the server.
I'm checking the log and I don't see any connection from your controller.
The libraries I pushed today has a change on the submission page.
Can you try that?
Can you try that?
What do you mean? Update my libraries? I'll look into that when I get home tonight. Leaving work now and have to run an errand before I get home so I'll be away for a couple hours.
OK Roberto. Updating the Libraries seems to have fixed my portal. It's working again!
My webbanner doesn't seem to have been updated though. Do I need to put a command in my .ino to update the webbanner or does that get updated automatically through the portal?
I do have that in my code though:
// Autogenerated file by RAGen (v1.2.1.158), (03/08/2012 22:54)
// RA_030812_2254.ino
#define DisplayImages
#define DateTimeSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define SaveRelayState
#define RelayExp
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x16
#define NUMBERS_8x16
#include <avr/wdt.h>
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 PWM channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
// Globals Needed for Params on Custom Main
byte x,y;
int v;
byte vtechmode;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " George's 75G Reef ");
// Display T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Tank");
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
// Display the T2 Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,53,14,"Sump");
// Display the T2 Temp Value
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
// Display Vortech MP40wES Mode Header Text
ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
// Display PMW Expansion Channel Headers and % Values
ReefAngel.LCD.Clear(DefaultFGColor,5,65,127,65);
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,31,68,"LED Dimming");
x=15;
y=78;
for (int a=0;a<4;a++)
if (a>1) x=75;
if (a==2) y=78;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch :");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+12,y,a);
//v = int(ReefAngel.PWM.GetChannelValue(a));
v = int(ReefAngel.PWM.GetChannelValue(a)/2.55);
ConvertNumToString(text, v, 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+24,y,text);
y+=10;
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox(13, 109, TempRelay);
//Draw Date & Time
void DrawCustomGraph() // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
ReefAngel.OverheatProbe = T1_PROBE; // Will change to T3_PROBE when can extend the T3 Probe to reach canopy.
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit |Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
// ReefAngel.Relay.On(Port1); Temporary taking this out to see if StandardATO code works
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// ReefAngel.Relay.On(Box1_Port8);
//--------------------------------------------------------- RF Module Setup -------------------------------------------------------
// This section commented out because it prevented RF Module from syncing with Vortech
/* ReefAngel.RF.SetMode(Slave_Start,0,0);
If you get a compile error similar to this:
'class ReefAngelClass' has no member named 'RF'
Please make sure that you enabled RF Expansion on your features file.
Open RAGen and make sure you have RF Expansion checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
#define RFEXPANSION
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(128);
//------------------------------------------------------ End RF Module Setup ------------------------------------------------------
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
// Specific functions
ReefAngel.Refresh(); //WDT check
ReefAngel.StandardATOExtended(Port1); // ATO using Internal Memory for timeout
ReefAngel.StandardHeater(Port2);
ReefAngel.StandardFan(Box1_Port7);
ReefAngel.ActinicLights(Box1_Port1); //Left Blue LEDs
ReefAngel.ActinicLights(Box1_Port2); //Right Blue LEDs
ReefAngel.DayLights(Box1_Port3); //Left White LEDs
ReefAngel.DayLights(Box1_Port4); //Right White LEDs
ReefAngel.MoonLights(Box1_Port5); //Left Moonlight
ReefAngel.MoonLights(Box1_Port6); //Right Moonlight
ReefAngel.MoonLights(Port4); //Fuge light on when main lights are out
//------------------------------------------------ Start PWM Expansion Code for Slope ----------------------------------------------
ReefAngel.PWM.SetChannel(LEDPWM0,int(PWMChannel[LEDPWM0]));
ReefAngel.PWM.SetChannel(LEDPWM1,int(PWMChannel[LEDPWM1]));
ReefAngel.PWM.SetChannel(LEDPWM2,int(PWMChannel[LEDPWM2]));
ReefAngel.PWM.SetChannel(LEDPWM3,int(PWMChannel[LEDPWM3]));
ReefAngel.PWM.Channel0PWMParabola(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel1PWMParabola(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
//------------------------------------------------- End PWM Expansion Code for Slope ----------------------------------------------
//------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
//-------------------------------------------------------- Moonlight Schedule -----------------------------------------------------
if ( NumMins(hour(),minute()) < 450 ) // Turn off Moonlights from Midnight to 7:30 MAM
ReefAngel.Relay.Off(Box1_Port5);
ReefAngel.Relay.Off(Box1_Port6);
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//------------------------------ Start Feeding Mode Schedule (Start 1st Feeding at 9:55 AM and 2nd at 1:55 PM)---------------------
// if the hour is 9a or 1p, minute is 55 and seconds is 0
// start the feeding mode
if ( ((hour() == 9) || (hour() == 13)) &&
(minute() == 55) &&
(second() == 0) )
ReefAngel.FeedingModeStart();
vtechmode = InternalMemory.RFMode_read();
//------------------------------------------------------ End of Feeding Mode Schedule ---------------------------------------------
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
if (hour() >=8 && hour() <= 22)
if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
bFeeding=false;
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,155,5);
ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
ReefAngel.Timer[4].Start();
vtechmode = 5;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
ReefAngel.RF.UseMemory=true;
//---------------------------------------------------------- End RF Daytime Control -----------------------------------------------
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=23 || hour()<7) // Defining "Nightmode" hours for VorTech = between 11 PM and 7 AM
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("TanksNStuff");
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
//------------------------------------------------------ End Time-of-Day Based Functions ------------------------------------------
//--------------------------------------------------------------- End Loop --------------------------------------------------------
// ToDo List Functions that still need to be added above:
// 1. Add Sunrise/Sunset/MoonPhase/Cloud Chance, etc. (PWM Slope data may be altered by these?)
// 2. *Option for later date* Relay box Ports 7 and 8 changed to "Off" normally, then add line in Loop to power them on if Overheat
// Shutoff is active (when I get fans to plug into those ports.)
