Hi Folks!
I find my controller lately reseting by itself every minute and sometimes every second.
I have tried to reset the controller and setup the memory and started it from 0 but I doesn´t
work...keeps reseting. I have a video if it helps.
http://www.youtube.com/watch?v=-wE6IUuWwXc
[youtube]http://www.youtube.com/watch?v=-wE6IUuWwXc[/youtube]
Thank you in advance.
Erick
controller reseting every minute
pilonstar
Re: controller reseting every minute
Does it do that with the Template code too?
File->Sketchbook->Example Codes->Template
pilonstar
I have tried that one too and stops for a while but once I put mine goes nuts:rimai wrote:Does it do that with the Template code too?
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.MHLights(Port1);
ReefAngel.StandardHeater(Box1_Port2);
ReefAngel.StandardLights(Port4);
ReefAngel.StandardFan( Port6 );
ReefAngel.SingleATOLow( Box1_Port1 );
ReefAngel.RF.RadionChannels[Radion_Intensity]=75;
ReefAngel.RF.RadionChannels[Radion_White]=PWMParabola(12,0,18,0,0,100,0);
ReefAngel.RF.RadionChannels[Radion_RoyalBlue]=PWMParabola(9,0,22,0,0,100,0);
ReefAngel.RF.RadionChannels[Radion_Red]=PWMParabola(9,0,22,0,0,5,0);
ReefAngel.RF.RadionChannels[Radion_Green]=PWMParabola(9,0,22,0,0,10,0);
ReefAngel.RF.RadionChannels[Radion_Blue]=PWMParabola(10,0,21,0,0,60,0);
if (second()==0) ReefAngel.RF.RadionWrite();
ReefAngel.Portal( "pilonstar" );
int x,y;
// I/O Expansion
byte bkcolor;
x = 14;
y = 11;
for ( int a=0;a<6;a++ )
ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,63, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,63, ReefAngel.Params.Salinity );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 82, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 101, TempRelay );
// Date and Time
Thanks for your patience and fast reply.
I posted the original firmare on the other thread for you to try to revert back and see if it makes any difference.
pilonstar
After resetting all from zero, the controller is working back perfect! yay!! Thank you so much Mr Rimai, Really appreciated your patience and helprimai wrote:I posted the original firmare on the other thread for you to try to revert back and see if it makes any difference.
