Hi Roberto,
How could I add a new function to the menu? For example, my current menu has water change, feeding etc. I wanted to add a lights on function. Many times I need to look at something in the tank and it's after the lights have gone out. Unplugging something from the relay box and plugging it into the wall is my only way of doing it now. I would specify which sockets to turn on in lights on mode. Can that be done?
New Menu Item
Re: New Menu Item
Can you post your current code?
What you would need to do is use the LightsOn functionality.
Here is an example code:
The MenuEntry functions control what the functions do. The menu_label variables control what functions are displayed.
Using the LightsOnPorts allows you to make use of the built-in functionality for turning the lights ON/OFF.
This should be able to get you started.
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "Lights On";
prog_char menu3_label[] PROGMEM = "Lights Off";
menu0_label, menu1_label, menu2_label, menu3_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry4()
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
// Initialize the custom menu
ReefAngel.LightsOnPorts = Port4Bit | Port5Bit;
