How long of a USB extension cord can I use?
I tried to look this up and couldn't find any answers.
Thank you.
USB cord how long?
Ademster
Re: USB cord how long?
how ever long you need I run a 8 foot usb on mine no problems. Albeit i only use it when programing the controller
Adam
58 Gal
58 Gal
Are you talking about the programming cable?
I use a 15ft cord, but I only connect when programming too. I see no problems with leaving it connected if you want.
I did however see that when you go far on USB, it is always best to use an active USB extension cable, instead of the plain extension.
rossbryant1956
what is an "active usb" cable?
http://www.monoprice.com/products/produ ... 1&format=2
They have some booster of some sort to allow the usb signal to travel far.
