ato port to pwm
jonegross
ato port to pwm
Post by jonegross »
So I have read one can do this, but could not find any code. What I want to do is use one of the ATO ports to control my red led driver. I currently use single low ato. Will I be able to use one port for ato and the other for pwm driver control? I have read the port only does 0-5v, which I think should be fine as I only want to run the red channel at maybe 400mA at peak. What would the code look like? So is there some call to make the port a pwm channel?
some command that changes function of ato port?
then in the loop
ReefAngel.PWM.SetATO(PWMSlope(10,30,22,30,1,80,120,ReefAngel.PWM.GetATOValue()));
What are my options for more pwm ports? Does the relay expansion module have 2 more pwm ports? Think I will run need more relays soon anyway...
Oh does the wifi module include everything needed, or is there a cord or something I would need to order?
Thanks for any help
Re: ato port to pwm
You can use Low ATO port as a third PWM output channel, which can only output 0-5V PWM.
Since you seem to be only willing to run at 400mA, you should be fine using the meanwell driver on this port.
Here is the code to use:
  pinMode(lowATOPin,OUTPUT);
  analogWrite(lowATOPin,PWMvalue);
Alternatively, a PWM expansion module can give you 6 more channels.
The wifi attachment comes with the cable to connect to the RA head unit.
jonegross
Re: ato port to pwm
Post by jonegross »
Thanks for the quick reply.
hous0067
Re: ato port to pwm
Post by hous0067 »
Hi,
Noob question: I'm trying to get pwm fans (not led) to dim using the ato low port as a 0-5v pwm driver. I wired up the fans with a separate 12v power supply, I just want a control signal from the ato + port.
I've read enough to think I need the codes below...can someone also help me with exactly where I'm supposed to put these commands in the code? :oops:
BlowerSpeed=map(ReefAngel.Params.Temp[T3_PROBE],772,789,30,100); // Calculate Blower speed
BlowerSpeed=constrain(BlowerSpeed,0,100);
Thanks in advance!
hous0067
-Ken
Re: ato port to pwm
Add to your loop() section.
analogWrite(lowATOPin,BlowerSpeed);
hous0067
Re: ato port to pwm
Post by hous0067 »
Thanks for the fast reply, Roberto!
Compiler crashed, I'm not sure what I'm doing wrong...
"Error: 'BlowerSpeed' was not declared in this scope" ?
I have Library version 1.0.1
Here's the code I tried to compile, Wizard code and added those lines to the custom loop.
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 845 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,725,735 );
ReefAngel.StandardLights( Port2,9,0,21,45 );
ReefAngel.StandardLights( Port3,9,0,21,0 );
ReefAngel.StandardLights( Port4,9,0,21,0 );
ReefAngel.WavemakerRandom( Port5,180,300 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.Relay.DelayedOn( Port8,3 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,21,0,10,100,10) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,21,0,10,100,10) );
ReefAngel.Portal( "hous0067" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
// Main Relay Box
// Date and Time
-Ken
Re: ato port to pwm
You must declare it at the top of the code.. Sorry.
int BlowerSpeed;
 int x,y;
 // Parameters
 // Salinity
 // Main Relay Box
 // Date and Time
hous0067
Re: ato port to pwm
Post by hous0067 »
Thanks, Roberto, that code compiled and loaded perfectly!
One more question; I have an analog dimming controller (apollo lights), will it make a pwm signal for the atolow port? ...just curious...my fans are still just idling like they aren't getting a signal, but it could be the fans...or my soldering...or both... :)
-Ken
-Ken
Re: ato port to pwm
Yes, the analog conversion happens on the relay box.
The ATO ports will output PWM signal.
If they are just idling and temp is between 77.2 and 78.9, there is something else wrong.
Do you have a meter?
Can you measure the voltage on the ATO port pins?
hous0067
Re: ato port to pwm
Post by hous0067 »
I actually changed the code to always be at 100%, just to see if I could get the fans to respond (they didn't).
My meter says 2.5v AC across the atolow. (1.85+/-.01 DC)
-Ken
Re: ato port to pwm
Oh, you know what....
The mapping is wrong.
The raw value ranges from 0-255, where 100% is 255.
That's why you are getting around 1.85VDC. That's the equivalent to 100/255 when you apply to 5V.
So, your code needs to be like this:
BlowerSpeed=map(ReefAngel.Params.Temp[T3_PROBE],772,789,76,255); // Calculate Blower speed
 BlowerSpeed=constrain(BlowerSpeed,0,255);
76 is 30% of 255
255 is 100% of 255
