Are there new libraries available to use the new Portal features to set your internal memory?
This should help so i don't have to hookup my computer to make changes. However if i have things specified in my pdo file will they overwrite the internal memory settings? If so, i need to take them out of my file so i can make changes on the fly correct?
New libraries?
Re: New libraries?
The latest is v1.0.1
If you aren't using this version, I recommend you download the RA installer and installing it to update your libraries.
You are correct on removing the settings from your code.
They will always take higher priority and if set in your code, the controller will disregard the memory settings.
I suggest you also try the Reef Angel Wizard and choosing memory settings.
Tools->Reef Angel Wizard
rossbryant1956
Re: New libraries?
I downloaded the new versions today and do not have tools\reef angel wizard. Arduino says I have 1.01. Please advise. Thx
Fixed it. Same thing happens to me every time. If I do not remember to rename the old directories before installing, something goes bonkers. All seems well now. Thx
