Help can't upload...
catman78
Post by catman78 »
Hi all,
trying to get going here and had a few ?
1. Controller has 8 pin connector and USB cable has 6 pin female
Where do I connect to?
2. Maybe 1 has to do with error I'm receiving when trying to upload.
Keeps saying error occoured try again. "Set RTS on Close" is enabled for port 5.
I'm using the Wizard to upload. Basic stuff, code looks fine.
thanks
Re: Help can't upload...
1. Please refer to the users manual. It shows a photo of how it should be conneted.
2. Most likely you are connecting it wrong or you have the wrong board. Make sure you select the correct board on Tools->Board.
catman78
Post by catman78 »
Thanks Roberto,
Have it plugged in correctly now.
still getting error.
I have basic Reef Angel Controller. I selected that from Tools/ board.
I then selected File/Upload.
Here's message
Watchdog Timer
Version Menu
Dimming Signal
Standard Menu
Binary sketch size: 27,394 bytes (of a 30,720 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM5 -b57600 -D -Uflash:w:C:\Users\Mark\AppData\Local\Temp\build7155545787251712395.tmp\sketch_sep01a.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM5
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
avrdude done. Thank you.
If you didn't buy your RA 2 years ago, you must use Reef Angel Controller w/ optiboot.
catman78
Post by catman78 »
tried that, still n/g. same error message
catman78
Post by catman78 »
here's the code I'm trying to uplaod.
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port2,11,45,20,0 );
ReefAngel.StandardLights( Port3,12,0,18,30 );
ReefAngel.StandardLights( Port4,21,0,10,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(11,0,20,30,10,100,60,10) );
ReefAngel.PWM.SetActinic( PWMSlope(10,30,21,0,10,100,60,10) );
It's not related to the code.
You have the black wire all the way to the right pin, correct?
Does the controller reboot a few seconds after you hit upload?
Can you post a pic of your connection and the error message you are getting with the new board selected?
catman78
Post by catman78 »
rimai wrote:It's not related to the code.
yes,
controller reboots after upload selected
error uploading
Watchdog Timer
Version Menu
Dimming Signal
Standard Menu
Binary sketch size: 27,394 bytes (of a 32,256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\Mark\AppData\Local\Temp\build9023571786502720875.tmp\sketch_sep01a.cpp.hex:i
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Recv:
And you are positive that COM5 is the correct serial port, right?
catman78
Post by catman78 »
yeah, . When I plug in USB cable 5 becomes enabled.
