Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /status/submitp1.aspx
Not sure if it's the new site (which is great, btw), but when I try to change the name of the T2 label, I get this:
Server Error in '/' Application.
The resource cannot be found.
Version Information: Microsoft .NET Framework Version:2.0.50727.4016; ASP.NET Version:2.0.50727.4016
Im still getting the 404 error as stated by lnevo, if i try to change a label after submitting the form i get the 404 error.
EDIT: I also found a small little formatting bug on the main page as well. If you're sitting on reefangel.com and you type something into the search field, once you search that term <ul class="bottommenu"></ul> gets pushed into <div class="top1"></div>
I think you need to refresh the portal page. I have corrected it, but you may still have the old js file in cache.
Thanks for pointing out the formating issue on the website
