How to setup your wifi attachment
symon_say
- Contact:
Re: How to setup your wifi attachment
I'm trying to reset my wifi adapter and i'm having trouble doing it, i tried the new app for setting wifi and i get the false statement on blue led blinks, i tried the older utility and i get this:
CMD
set w a 4
AOK
<2.32> set w p xxxxxxx
AOK
<2.32> set w s xxxxxx
AOK
<2.32> set i l 2000
AOK
<2.32> save
Storing in config
*BAD CONFIG*
<2.32> reboot
*Reboot*
What should i do?? i Know is not my router cause it was working this morning, i was just trying to set with the new utility to see if i lose connection less often.
CMD
set w a 4
AOK
AOK
AOK
<2.32> set i l 2000
AOK
<2.32> save
Storing in config
*BAD CONFIG*
<2.32> reboot
*Reboot*
symon_say
- Contact:
I tried now, but it didn't work, still getting false statement on the new utility, and on the old one everything seen ok, but adapter don't connect to router.
mad28gnc@yahoo.com
I can't find my ssid
mad28gnc@yahoo.com
For some reason it doesn't work
Both SSID and password is case sensitive.
I also recommend WPA2-PSK with AES encryption.
I've seen some of the other security options giving problems in the past.
Also, does either the SSID or password have a space in it?
mad28gnc@yahoo.com
I have two different routers I tried them both and yes one does have a space in the name
mad28gnc@yahoo.com
Does my router need to be plugged in to my computer?
No, it does not need to be plugged into the computer.
Try replacing the space with a $ sign.
mason dixon
How do I upload the wifi test code to the reef angel?
I have a 6 pin usb/ttl cable but the input on the reef angel is 8 pin?
I also have a ttl cable that is 6 pin female on one side and 8 pin female on the other?
thanks
thanks
The USB-TTL cable can be used to upload codes to RA and also to setup the wifi attachment.
The 6pin-8pin is to be used when you want to connect RA to the wifi attachment.
Black wire is always to the right-most pin. Please check the manual for instructions on how to connect.
- cody.sheridan-2008
Hi there,
With the 2nd type of connection, will it work if there is no passphrase? I am not sure why it would but it does nothing once I click "setup wifi attachment" just leaves black. I have talked to my master (father) and it is all to hard to put one on to try
I am getting to this point and then nothing.
Cheers
Cody
Cody
yeah typed i a random bunch of letters and it did something but obviously didn't work. here comes the next 6 months battling to get one lol
Cheers
Cody
Cody
Hey roberto,rimai wrote:I don't think it would work with no password
The wifi attachment will work if you have no password you just need to put a space in the box.
Cheers
Cody
Cody
cgonser
I so far have had a sucessful install until I go to type the IP in the address bar, then I get no connection. Set up went well, have only a green light blinking, but no connection. Any advice?
If you have a green blinking light then it should be good. Check in your router and see what ip address was assigned.
cgonser
no clue how to do that! I copied the address the set up wizzard gave me...?lnevo wrote:If you have a green blinking light then it should be good. Check in your router and see what ip address was assigned.
What ip address? Can you ping it from the command prompt?
You just put the ip in the address bar? You need the port too... Like this
http://192.168.1.20:2000
cgonser
I tried that exact thing, but my address is obviously different.. I just get page can not be displayed
dbmet
cgonser
Seems to be figured out now, but when I use the iphone app, I can only get my readings when my phone is hooked up to the in house wifi, not 3gdbmet wrote:What kind of router do you have?
00Warpig00
cgonser wrote:Seems to be figured out now, but when I use the iphone app, I can only get my readings when my phone is hooked up to the in house wifi, not 3gdbmet wrote:What kind of router do you have?
Sounds like your router is either not allowing traffic in from the internet on port 2000 OR your iphone does not know your home network's public IP address, or BOTH.
You can use http://www.whatismyip.com to determine your public IP address on your home network and you can use http://www.canyouseeme.org/ to probe your home network's port 2000 from the internet for a response. Also note if your ISP is connecting you to the internet via dynamic IP address you may also need to use a dynamic DNS service like DYNDNS.ORG
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
cgonser
I'm guessing its the iPhone that's the problem? I went to both sites and everything seems good. Port 2000 is open and communicating.
You need to set your iPhone to use the public ip...not the internal one you got when you setup the module... Then you can use a dynamic dns service to give that ip a name so if your provider changes your ip your RA will still work.
And from inside the outside address should work with most routers...
Elevatorguy1
Ok, I'm confused. So if I load the wifi test code won't that erase the code I'm using now to run my tank?
You should have your older code saved and just reload it after the test. You can also modify it so that the ports you need are on while testing.
