I just got my RA and I have the newest Mac OS 10.8.1. When I try to open the wifi utility, it says “Wifi_Utility.app” is damaged and can’t be opened. You should move it to the Trash."
I've tried downloading the whole installation DMG several times and it does this each time. I restarted the computer after installation of the other files and that made no difference. I can't open it from the disk image or from the application folder. Any help?
I can't get wifi utility to load on Mac OS
Re: I can't get wifi utility to load on Mac OS
I'm not a good mac user, but googling, I found this:
https://discussions.apple.com/thread/39 ... 0&tstart=0
Can you try that suggested solution and see if that helps?
It says something to do with gatekeeper, but that solution was for 10.7.4, but I think would work for your version too.
Here is another one:
http://www.minecraftforum.net/topic/139 ... -13-issue/
seamonkey
The second post fixed it. You are a better "googler" than I am. I had searched and didn't find anything. Thanks!
