Parameter out of range warning flasher
jsclownfish
Post by jsclownfish »
I'm adding a little function on my display to flash the numbers red when they are above or below where I expect them to be so they are easy to see. I thought it might be useful if others want to use it as well and maybe we could add it to future libraries. There might be easier ways to do this as well. Here is my attempt....
//function to flash warning (parameter, high limt, low limit, x, y, decimal)
void Warningflash(int param, int high, int low, byte x, byte y, byte z)
  int mod=second()%2;
  if (param > high || param < low)
     if (mod==0) ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+40,y+10);
     else ReefAngel.LCD.DrawSingleMonitor(param, COLOR_RED, x, y, z);
 else ReefAngel.LCD.DrawSingleMonitor(param, DefaultFGColor, x, y, z);
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
  // Display the PH with color sensors
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 13,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 23, 13, 100);
Warningflash(ReefAngel.Params.PH, 840, 790, 23, 13, 100);
I'll try this tonight to see how it goes.
-Jon
Re: Parameter out of range warning flasher
Awesome idea! Should definitely be in the libraries as a standard function..
DrawSingleMonitorFlash()
DrawSingleMonitorAlarm()
or even just override the existing DrawSingleMonitor();
void DrawSingleMonitor(param, color, x, y, z, high, low, warning_color?); ?
I think I like the override personally, not sure if that will be more confusing to some...
Wanna try to create a pull request :)
rimai wrote:Wanna try to create a pull request :)
Sure. which method did you prefer though?
I do need to get back to the git stuff so I can clone off your dev branch and start the commenting process again...
I'm in montreal for the week for business so next week I can setup the function. Any feedback on the function declaration I put? I can rearrange the params, etc on feedback...
Lee
yes, fork the latest dev branch and work on it. When you are done, send a pull request.
I personally like DrawSingleMonitorAlarm() :)
Cool, I'm not partial, and long term that will be less confusing for people who may not understand overridden functions...
Ok, I've cloned the repo again... merged with dev and added the DOxygen title page and the function DrawSingleMonitorAlarm function... here's the declaration
void DrawSingleMonitorAlarm(int Temp, byte fcolor, byte x, byte y, byte decimal, byte high, byte low, byte wcolor);
So the params are the same as DrawSingleMonitor with the addition of high, low and warning color to the args.
Hopefully my pull request is good, but it seems two seperate commits happened, and the second was after the pull request, so I'm not 100% sure what I'm doing git wise...
Lee
Ok, I think I finally made a clean pull request for this function :)
Yeap :)
It will be in the next lib release.
enigma32
Post by enigma32 »
haha- I was reading this thinking, "oh, I should +1 this"... then I looked at the dates :-)
This is great. I have a question re: the method prototype though.
Isn't it a problem that "Temp" is an int and "high" and "low" are bytes?
Current setup:
60g 24" custom cube (fish and softies right now)
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
100% customer controller, transitioning to ReefAngel
Yes.
Pushed the fix :)
enigma32
Post by enigma32 »
haha excellent
Current setup:
Coralife skimmer
