I am trying to get 2 (Port4 and Port6) of my powerheads to come on for 6 hours, while the other one (Port5) is off. After 6 hours, it's swapped, Port5 on for 6 hours, Port4 and Port6 off for 6 hours.
I uploaded it and Port5 was on, and not Port4 and Port6. Is this code correct?
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
//ReefAngel.Relay.On( Port4 );
//ReefAngel.Relay.On( Port5 );
//ReefAngel.Relay.On( Port6 );
ReefAngel.DayLights( Port1 );
ReefAngel.StandardFan( Port3 );
ReefAngel.Relay.DelayedOn( Box1_Port2 );
ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.Wavemaker(Port4,21600);
ReefAngel.Wavemaker(Port6,21600);
ReefAngel.Relay.Set(Port5,!ReefAngel.Relay.Status(Port6));
ReefAngel.Portal( "agentgreen", "**********" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
// Date and Time
