Need some help with second temp probe not displaying temp. I have swapped both probes to between port 1 and port 2 the new temp probe does not show temp now matter where it is plugged in.
Here is the code.
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
ReefAngel.StandardATO( Port1 );
ReefAngel.DosingPumpRepeat1( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.Relay.Set( Port4, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.WavemakerRandom1(Port5,20,60); // Turn Port5 on/off random cycles that lasts from 20 to 60 secs
ReefAngel.WavemakerRandom2(Port6,20,60); // Turn Port6 on/off random cycles that lasts from 20 to 60 secs
// Port 5 and 6 are not synchronized.
// They work independent of each other at random times.
buzzer = overheatflag + atoflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetActinic( buzzer );
ReefAngel.Portal( "riggeek" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
// Main Relay Box
// Date and Time
second temp probe not displaying on T2
riggeek
riggeek
Re: second temp probe not displaying on T2
Just did the reboot. that got it working. T1 and T2 swapped on the reboot. How does the controller determine which one is T1 and T2?
riggeek
A serial number is laser inscribed on manufacturing and determined by the order they are manufactured.
So T1 will be the oldest to be manufactured and T3 would be the newest.
