Custom code, please help
Re: Custom code, please help
If you get it connected again and configured, it should show up within 5 minutes
Still nothing, in the RA code I have only the my forum username. Do I have to add the pass too?
I added it since my portal requires security key. I hope this will fix it.
yes, if you entered in the portal settings, you need to add it in your code too.
Roberto, I have the following code:
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port8Bit | Port7Bit;
I'd like to turn on port 3 & 4 during water change.
Please help. Thanks
Please help. Thanks
Do you want them on/off based on water change or they do something else too?
just to turn them on 3& 4 when i do water change..those are led drivers.
port1&2 are the switches that move the driver from one channel of LED1/tank1 to another channel of LED2/tank2. When both switches 1&2 are off and 3&4 are on..the actinic lights from tank1&2 are on.
Aslo I have a problem..I changed the code yesterday.. and ReefAngel.StandardLights(Port4,10,0,20,0); doesn't engage port4. What am I doing wrong? Thank you
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
ReefAngel.Init();
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit;
ReefAngel.Relay.On(Port8);
ReefAngel.PHMin=560;
ReefAngel.PHMax=820;
ReefAngel.TempProbe=T1_PROBE;
ReefAngel.StandardFan(Port5,787,793);
ReefAngel.StandardHeater(Port7,775,785);
if (hour() > 10 && hour() < 20)
ReefAngel.StandardLights(Port1,11,1,19,0);
ReefAngel.StandardLights(Port3,11,0,19,0);
ReefAngel.PWM.SetDaylight(PWMSlope(11,0,19,0,0,0,180,0));
ReefAngel.PWM.SetActinic(PWMSlope(10,0,20,0,0,20,180,0));
ReefAngel.StandardLights(Port3,20,0,6,0);
ReefAngel.StandardLights(Port4,21,0,5,0);
ReefAngel.StandardLights(Port2,21,1,5,0);
ReefAngel.PWM.SetDaylight(PWMSlopeOvernight(20,0,6,0,0,20,180,0));
ReefAngel.PWM.SetActinic(PWMSlopeOvernight(21,0,5,0,0,0,180,0));
if (ReefAngel.Params.Temp[T2_PROBE] >= 1200 || ReefAngel.Params.Temp[T3_PROBE] >= 1200) {ReefAngel.Relay.On(Port6);}
if (ReefAngel.Params.Temp[T2_PROBE] < 1100 && ReefAngel.Params.Temp[T3_PROBE] < 1100) {ReefAngel.Relay.Off(Port6);}
ReefAngel.Portal("d0lph1n","*****");
byte PWMSlopeOvernight(byte startHour, byte startMinute, byte endHour, byte
endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
unsigned long Start = previousMidnight(now())+((unsigned long)NumMins(startHour, startMinute)*60);
if (hour()<startHour) Start-=86400;
unsigned long StartD = Start + (Duration*60);
unsigned long End = nextMidnight(now())+((unsigned long)NumMins(endHour, endMinute)*60);
if (hour()<startHour) End-=86400;
unsigned long StopD = End - (Duration*60);
if ( now() >= Start && now() <= StartD )
return constrain(map(now(), Start, StartD, startPWM, endPWM),startPWM,
endPWM);
else if ( now() >= StopD && now() <= End )
byte v = constrain(map(now(), StopD, End, startPWM, endPWM),startPWM,
endPWM);
return endPWM-v+startPWM;
else if ( now() > StartD && now() < StopD )
return endPWM;
return oldValue;
memory
// Autogenerated file by RAGen (v1.2.2.171), (04/14/2012 12:05)
// Memory_041412_1205.ino
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(10);
InternalMemory.MHOffHour_write(18);
InternalMemory.StdLightsOnHour_write(22);
InternalMemory.StdLightsOffHour_write(6);
InternalMemory.WM1Timer_write(200);
InternalMemory.FeedingTimer_write(1800);
InternalMemory.LEDPWMDaylight_write(0);
InternalMemory.LEDPWMActinic_write(0);
InternalMemory.HeaterTempOn_write(778);
InternalMemory.HeaterTempOff_write(785);
InternalMemory.PHMax_write(820);
InternalMemory.PHMin_write(560);
InternalMemory.DP1RepeatInterval_write(0);
InternalMemory.DP2RepeatInterval_write(0);
InternalMemory.PWMSlopeStartD_write(0);
InternalMemory.PWMSlopeEndD_write(100);
InternalMemory.PWMSlopeDurationD_write(180);
InternalMemory.PWMSlopeStartA_write(0);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.PWMSlopeDurationA_write(180);
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(100);
InternalMemory.PWMSlopeStart0_write(0);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(0);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(0);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(0);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(0);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(0);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
ReefAngel.Init();
endPWM);
endPWM);
return endPWM;
return oldValue;
memory
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
delay(5000);
Try this:
ReefAngel.Relay.RelayMaskOn|= Port3Bit |Port4Bit;
ReefAngel.Relay.RelayMaskOn&= ~(Port3Bit |Port4Bit);
rimai wrote:Try this:Code: Select all
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.Relay.RelayMaskOn|= Port3Bit |Port4Bit; else ReefAngel.Relay.RelayMaskOn&= ~(Port3Bit |Port4Bit);
Is it going to fix the other problem too of port 4 not turning on at 10am?
The code you posted changes at 11am not 10am.
>10 means anything greater than 10, which would be 11.
If you want including 10, you need to use >=10
wow, thanks a lot, now it makes sense why everything started to work at 11am.rimai wrote:The code you posted changes at 11am not 10am.
Hello Roberto, I'd like to connect the relay expansion module. I couldn't find a newer version of the user manual. What new lines of code do I have to add to activate it, how do I control the new plugs?
Just use them the same way, but you must reference them with Box1_ in front of the port.
Like this:
Like this:
Do I have to open RA and follow the instructions " You need to place the provided jumpers to the SDA and SCL pins."
If the jumpers are not there, yes.
Recent boards are coming with those pre-installed.
it's a Unit 6.1, it has only the RST jumper is pre-installed, the others are empty
I was able to manage it. Thx.
Now, for dosing purposes, is it possible to control the relay port in seconds?
I don't want to mess with the existing code. Let me give it a try.
You don't need to mess with your current code.
You can generate a code with just one port and see how the function works, then copy and paste in your current code.
Great. Thanks a lot. I didn't know about the wizard.
I've dled the latest RA for windows.
I've reloaded the mem code and the RA code and it displays the following error:
"No internal memory found"
What am I doing wrong:
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.OverheatTemp_write(830);
InternalMemory.PHMax_write(860);
InternalMemory.PHMin_write(537);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeStart5_write(15);
delay(5000);
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
ReefAngel.Init();
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.PHMin = 537;
ReefAngel.PHMax = 860;
ReefAngel.DosingPumpRepeat(Box1_Port1,0,120,2);
ReefAngel.DosingPumpRepeat(Box1_Port1,1,120,2);
if (hour() >= 10 && hour() < 20)
ReefAngel.StandardLights(Port4,10,0,19,59);
ReefAngel.StandardLights(Box1_Port3,11,0,19,0);
ReefAngel.PWM.SetActinic(PWMSlope(10,0,19,59,0,20,180,0));
ReefAngel.StandardLights(Box1_Port4,21,0,5,0);
ReefAngel.Portal("d0lph1n","******");
endPWM);
endPWM);
return endPWM;
return oldValue;
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
delay(5000);
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
ReefAngel.Init();
endPWM);
endPWM);
return endPWM;
return oldValue;
Please load the InitialInternalMemory code
File->Sketchbook->Example Codes->InternalMemoryCode
It worked. This is by far the best support I've ever received. Thanks a lot.
Unfortunately, none of the relay expansion box ports has power.
The relay expansion module led is green. I connected it to the main relay via the usb cable and to the 2nd relay box via svga cable. All 3 jumpers are on.
Your code looks good.
So, let's check if the controller sees the box.
Please load this:
Then, go to menu Tools-Serial Monitor and make sure you have 57600 baud.
The controller will output a lot of numbers. If it doesn't, you may need to reboot the controller with the window open.
Copy and paste the numbers here.
Please load this:
* I2CScanner.pde -- I2C bus scanner for Arduino
* 2009, Tod E. Kurt, http://todbot.com/blog/
#include "Wire.h"
extern "C" {
#include "utility/twi.h" // from Wire library, so we can do bus scanning
// Scan the I2C bus between addresses from_addr and to_addr.
// On each address, call the callback function with the address and result.
// If result==0, address was found, otherwise, address wasn't found
// (can use result to potentially get other status on the I2C bus, see twi.c)
// Assumes Wire.begin() has already been called
void scanI2CBus(byte from_addr, byte to_addr,
void(*callback)(byte address, byte result) )
byte rc;
byte data = 0; // not used, just an address to feed to twi_writeTo()
for( byte addr = from_addr; addr <= to_addr; addr++ ) {
rc = twi_writeTo(addr, &data, 0, 1, true);
callback( addr, rc );
// Called when address is found in scanI2CBus()
// Feel free to change this as needed
// (like adding I2C comm code to figure out what kind of I2C device is there)
void scanFunc( byte addr, byte result ) {
Serial.print("addr: ");
Serial.print(addr,HEX);
Serial.print( (result==0) ? " found!":" ");
Serial.print( (addr%4) ? "\t":"\n");
byte start_address = 1;
byte end_address = 128;
// standard Arduino setup()
Wire.begin();
pinMode(7,OUTPUT);
Serial.begin(57600);
Serial.println("\nI2CScanner ready!");
Serial.print("starting scanning of I2C bus from ");
Serial.print(start_address,DEC);
Serial.print(" to ");
Serial.print(end_address,DEC);
Serial.println("...");
// start the scan, will call "scanFunc()" on result from each address
scanI2CBus( start_address, end_address, scanFunc );
Serial.println("\ndone");
// standard Arduino loop()
// Nothing to do here, so we'll just blink the built-in LED
digitalWrite(7,HIGH);
delay(300);
digitalWrite(7,LOW);
delay(300);
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
done
done
The controller is not seeing the module.
It should be on #38.
Can you double check the cables and the jumpers?
When I connect/disconnect the svga cable in the 2nd relay box, the ports have power for a fraction of a second.
Inside the relay extension, all switches are off.
Now I have this and still no power:
I2CScanner ready!
addr: 35 addr: 36 addr: 37 addr: 38 found!
done
I2CScanner ready!
done
It's working. It was from the imperfect connection of my jumpers inside RA.
