I have a 110 Reef Savvy Rimless that I am setting up and want to purchase a Reef Angel but I have no idea which one I should purchase. I know I want the wireless option but that's about it. A
This is the equipment I want to control
Return pump-Mag 12
Skimmer-Reef Octopus 150
Lights- Ai Sols
Powerheads - 4 Korilla Evolutions (Soon to be 2 Mp 40's)
Reactors- Phosphate & Carbon
ATO Pump- SICCE MICRA PUMP 90GPH
ny help would be greatly appreciated.
Please help (Which Model)
Re: Please help (Which Model)
I think you should go with the Reef Angel Plus - PWM Dimming.
Then, add wifi, AI cable and RF module
treetopflyn
Why the plus? Also, I like my wireless controller Ai Controller (less cables) I think I will stick with that.
Do I need the RF now or can I wait until I buy the MP40's?
Ok, if you have the wireless ai controller, you won't need the ai cable.
You should be fine with the standard RA then.
You can get the RF module later.
treetopflyn
PWM correct?
It won't matter in your case.
You won't be using as you already have AI, so choose whichever you prefer.
alexwbush
definitely get the plus. Your code will get larger and larger as you customize and find great new things to add and code
