Rf
reefcycle
Rf
Last problem post I swear. I had RF setup before and thanks to Roberto I figured out that I am a moron. Lol. But when I first plugged in RF it was already solid purple. I have RA+ is there something im missing? I had this setup for long time and I feel like a newb when I have to tweak things.
Re: Rf
Can I see your code?
You must use UseMemory=true to be able to change on the Portal
ReefAngel.RF.UseMemory=true;
reefcycle
Re: Rf
I will attempt when I get home @ 545. But I will say one thing since I upgraded to RA + and used wizard instead of old method my heater port 3 was not auto engaging either. Lol I am so not a helpless person usually but I am so lost. And I must thank you rimai for all your help
reefcycle
Re: Rf
not sure if this is latest but it is close.
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.OverheatTemp_write( 829 );
InternalMemory.StdLightsOnHour_write( 0 );
InternalMemory.StdLightsOnMinute_write( 0 );
InternalMemory.StdLightsOffHour_write( 18 );
InternalMemory.StdLightsOffMinute_write( 0 );
InternalMemory.ActinicOffset_write( 0 );
InternalMemory.HeaterTempOn_write( 760 );
InternalMemory.HeaterTempOff_write( 765 );
InternalMemory.ChillerTempOn_write( 775 );
InternalMemory.ChillerTempOff_write( 770 );
InternalMemory.DP1RepeatInterval_write( 60 );
InternalMemory.DP1Timer_write( 30 );
InternalMemory.DP2RepeatInterval_write( 65 );
InternalMemory.DP2Timer_write( 30 );
InternalMemory.IMCheck_write(0xCF06A31E);
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code");
reefcycle
Re: Rf
How about I start over. When I goto reef angel select wizard and start from scratch should I do set for code (new users) or set internal memory? After that I select my settings for port 1 time schedule port 2 time schedule port 3 heater port 4 fan port 5 & 6 unused port 7 dosing pump 1 and port 8 dosing pump 2. RF vortech reefcrest and set internal generate successful.
After I did that I resynced the vortechs since they and the RF module where not there and reset water level out of water and in water. When all said and done I have on android app water percentage temp Ph etc. Heaters I have to override lights are way off and need to be manually set and I can read and write memory on android app but when everything set to auto it is either all on or off. On portal it is showing way off options. I know this is something I am doing g completely wrong and I feel so helpless.. do any of those steps sound ridiculous?
Re: Rf
If you want to be able to change settings on the portal or android app, you must choose to store settings on internal memory.
This is what is going to place the correct settings in the memory and should also show the correct settings on both Portal and Android.
If you don't choose internal memory, all apps are just going to start pulling whatever crap is currently stored.
Then at the end, it will show you the code you uploaded, which you can save if you wish or not. You can always generate it again.
reefcycle
Re: Rf
oh here is the latest made code, with port settings and times and vortech control.
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.DayLights( Port2 );
ReefAngel.StandardFan( Port4 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.Portal( "reefcycle" );
int x,y;
// I/O Expansion
byte bkcolor;
x = 14;
y = 21;
for ( int a=0;a<6;a++ )
ReefAngel.LCD.DrawMonitor( 15, 46, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 46, ReefAngel.Params );
Re: Rf
Good.
You are missing the RF stuff, so just add this to your loop():
Re: Rf
reefcycle
Re: Rf
where shall I put it? I am looking at the code that worked and not wanting to lose all my progress. I am sorry roberto, I am going to be adding relay expansion since I need more amperage draw for lights and heaters. So I am at least buying stuff lol
Re: Rf
Use this:
int x,y;
// I/O Expansion
byte bkcolor;
x = 14;
y = 21;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,76, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,76, ReefAngel.WaterLevel.GetLevel() );
