Custom Main screen
Would you like to help?
PostPosted: Wed Oct 10, 2012 2:30 pm
I want to use the custom main screen that was made but I want to pull channel 0 and 1 off of the PWM add on.
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
  ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
  ReefAngel.LCD.DrawText(0,255,8,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
PostPosted: Wed Oct 10, 2012 3:02 pm
You don't want to show or you do want to show?
PostPosted: Wed Oct 10, 2012 4:41 pm
In the code it's pulling the CWLED and RBLED values from the built on dimming circuits. I want to pull channel 0 and 1 from the add on PWM dimming controller instead.
PostPosted: Wed Oct 10, 2012 4:55 pm
Use this instead:
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetChannelValue(0));
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetChannelValue(1));
PostPosted: Wed Oct 10, 2012 6:42 pm
two threads titled custom main screen(s) in tutorials.. uh ohhhh
PostPosted: Wed Oct 10, 2012 9:55 pm
Thanks Roberto, you are awesome.
Return to Tutorials
