I'm lost. First off I don't know where to post my problem. So here I am. My first question i when installing RA software windows at one point it sez do not have your usb-ttl connected to your computer. Next step it sez to plug it in... Should I have it plugged into the controller for this step or just plug in the cable only with nothing connected on the other end? I didn't hook up the controller in this step. Ok if I'm good so far when I try to upload the first time initial internal memory it sez
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 6,812 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\SCOOTS~1\AppData\Local\Temp\build7336776526629978680.tmp\InitialInternalMemory.cpp.hex:i
avrdude: Version 5.11.1, compiled on Apr 1 2012 at 09:58:16
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x32
avrdude done. Thank you.
Can someone help me Thank you
Error uploading Initial Internal Memory
scootscomputes
Re: Error uploading Initial Internal Memory
If I'm not mistaken, you have an RA+.
You must change the board to Reef Angel Plus Controller under menu Tools->Board
scootscomputes
cool thanks
