How many dosing pumps with the controller, and portal run? I can only see adjustments for 2 dosing units on the portal.
I am wanting to be able to control and adjust Cal. Alk, and Mag.
thanks
riggeek
Re: How many dosing pumps
The portal will only handle 2.
You can do as many as you want, but they would either have to be hard coded or you would need to use the android app.
