Ok. So I have a RA on my 120 mixed reef. I was out of three days and my RTA in my was ready to die in my 46 gallon because the water level dropped which raised the salinity. So, I hate wasting money. I need an ATO, I bought a wave l maker controller. And now I realize, again that a RA is cheaper than the route I am taking.
So I am considering buying another controller. My question is, how would I control two RAs remotely? I use my iPhone and the web portal extensively.
Multiple RA Units
carlii
Re: Multiple RA Units
Android supports 2 profiles to be setup, but not the iphone
The Portal also does not offer 2 profiles due to how the forum/database is setup, but you could always logout and login with another username to change the portal userid.
carlii
What about using different port numbers? The ports would have to be different right?
- Contact:
i have 2 ra units on my home network and just use 2 different ports on my router for access outside my network.
alexwbush
I run 2 as well. They're at different locations, but I will run different ports. To run portal, you'll have to create two profiles. But we'll fix that one day... right Roberto?
