Hardware Issue - Possible Water Damage
M@!
Right before heading on vacation I was setting up a larger Top Off container. Of course that happens to be the time that I'm pretty sure some water got into the unit. It flashed black for a second and I immediately unplugged power. I took it apart and put it into some rice to dry out. 24 hours later I plug it back in. It powers up and everything appears to be working accept for the menu selector. Any trouble shooting to figure out the menu selector or do you guys offer repair service?
Matt
Matt
Re: Hardware Issue - Possible Water Damage
Yes, you can load the ControllerTester code to test the joystick.
If you still have problems, you can PM me for repair.
M@!
Thanks, Left and right worked fine but pressing down is doing nothing. I'm guessing pressing down toggles the ports on/off?
M@!
Alright, received my RA back. All was working well accept the ATO was acting weird. It was turning on the wrong ports and then my RA would just die after running for a couple hours.
I realized my libraries were old so I installed the latest version of RA. Now I'm getting program out of sync errors.
I found this code
Serial.begin(57600);
Serial.println("Test");
In a different post and tried to upload it. I received the following error:
I found this code
Any ideas?The following features were automatically added:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 1,874 bytes (of a 32,256 byte maximum)
C:\Program Files\Reef Angel Controller222\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller222\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\mroit\AppData\Local\Temp\build5890161014538168828.tmp\sketch_nov10b.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller222\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [00]
avrdude: Send: A [41] . [98] [20]
Hardware Version: 3
Firmware Version: 4.0
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00] [20]
avrdude: reading input file "C:\Users\mroit\AppData\Local\Temp\build5890161014538168828.tmp\sketch_nov10b.cpp.hex"
avrdude: writing flash (1874 bytes):
Writing | avrdude: Send: U [55] . [00] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] 5 [35] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] . [f1] . [02] . [0c] . [94] ] [5d] . [00] . [0c] . [94] t [74] . [00] . [0c] . [94] . [bb] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] . [0c] . [94] ] [5d] . [00] ! [21] . [02] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d8] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [ec] . [e3] . [f7] . [e0] [20]
###avrdude: Send: U [55] @ [40] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [02] . [c0] . [05] . [90] . [0d] . [92] . [a6] 1 [31] . [b1] . [07] . [d9] . [f7] . [11] . [e0] . [a6] . [e1] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a6] < [3c] . [b1] . [07] . [e1] . [f7] . [10] . [e0] . [ca] . [e6] . [d0] . [e0] . [04] . [c0] " [22] . [97] . [fe] . [01] . [0e] . [94] . [98] . [03] . [c8] 6 [36] . [d1] . [07] . [c9] . [f7] . [0e] . [94] q [71] . [02] . [0c] . [94] . [9c] . [03] . [0c] . [94] . [00] . [00] . [08] . [95] . [0f] . [93] . [1f] . [93] . [0e] . [e9] . [11] . [e0] . [c8] . [01] @ [40] . [e0] Q [51] . [ee] ` [60] . [e0] p [70] . [e0] . [0e] . [94] . [f6] . [00] . [c8] . [01] ` [60] . [e0] q [71] . [e0] . [0e] . [94] . [de] . [02] . [1f] . [91] . [0f] . [91] . [08] . [95] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] O [4f] . [93] . [8f] . [93] . [9f] . [93] . [ef] . [93] . [ff] . [93] [20]
###avrdude: Send: U [55] . [80] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] @ [40] . [91] . [c6] . [00] [20] . [91] V [56] . [01] 0 [30] . [91] W [57] . [01] / [2f] _ [5f] ? [3f] O [4f] / [2f] s [73] 0 [30] p [70] . [80] . [91] X [58] . [01] . [90] . [91] Y [59] . [01] ( [28] . [17] 9 [39] . [07] Y [59] . [f0] . [e0] . [91] V [56] . [01] . [f0] . [91] W [57] . [01] . [ea] ^ [5e] . [fe] O [4f] @ [40] . [83] 0 [30] . [93] W [57] . [01] [20] . [93] V [56] . [01] . [ff] . [91] . [ef] . [91] . [9f] . [91] . [8f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [e0] . [91] . [aa] . [01] . [f0] . [91] . [ab] . [01] . [e0] \ [5c] . [ff] O [4f] . [81] . [91] . [91] . [91] [20] . [81] 1 [31] . [81] . [82] . [1b] . [93] . [0b] . [8f] s [73] . [90] p [70] . [89] + [2b] . [11] . [f0] . [0e] . [94] s [73] . [00] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] [20]
####avrdude: Send: U [55] . [c0] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [ef] . [93] . [ff] . [93] [20] . [91] . [9a] . [01] 0 [30] . [91] . [9b] . [01] . [80] . [91] . [9c] . [01] . [90] . [91] . [9d] . [01] ( [28] . [17] 9 [39] . [07] 1 [31] . [f4] . [80] . [91] . [c1] . [00] . [8f] } [7d] . [80] . [93] . [c1] . [00] . [14] . [c0] . [e0] . [91] . [9c] . [01] . [f0] . [91] . [9d] . [01] . [e6] Z [5a] . [fe] O [4f] [20] . [81] . [80] . [91] . [9c] . [01] . [90] . [91] . [9d] . [01] . [01] . [96] . [8f] s [73] . [90] p [70] . [90] . [93] . [9d] . [01] . [80] . [93] . [9c] . [01] [20] . [93] . [c6] . [00] . [ff] . [91] . [ef] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [af] . [92] . [bf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0f] . [93] . [1f] . [93] . [cf] . [93] . [df] . [93] . [ec] . [01] [20]
###avrdude: Send: U [55] . [00] . [01] [20]
avrdude: Send: d [64] . [00] . [80] F [46] z [7a] . [01] . [8b] . [01] . [dd] $ [24] @ [40] 0 [30] . [81] . [ee] X [58] . [07] . [80] . [e0] h [68] . [07] . [80] . [e0] x [78] . [07] . [11] . [f0] . [dd] $ [24] . [d3] . [94] . [91] . [e0] . [a9] . [2e] . [b1] , [2c] . [ec] . [89] . [fd] . [89] . [dd] [20] i [69] . [f0] . [c5] . [01] . [0e] . [8c] . [02] . [c0] . [88] . [0f] . [99] . [1f] . [0a] . [94] . [e2] . [f7] . [80] . [83] ` [60] . [e0] y [79] . [e0] . [8d] . [e3] . [90] . [e0] . [05] . [c0] . [10] . [82] ` [60] . [e8] t [74] . [e8] . [8e] . [e1] . [90] . [e0] . [a8] . [01] . [97] . [01] . [0e] . [94] t [74] . [03] ! [21] P [50] 0 [30] @ [40] @ [40] @ [40] P [50] @ [40] V [56] . [95] G [47] . [95] 7 [37] . [95] ' [27] . [95] . [80] . [e1] [20] 0 [30] 8 [38] . [07] [20] . [f0] . [dd] [20] . [11] . [f0] . [dd] $ [24] . [d6] . [cf] . [e8] . [89] . [f9] . [89] 0 [30] . [83] . [ea] . [89] . [fb] . [89] [20] . [83] [20]
avrdude: Recv: . [16]
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x16
avrdude: Send: V [56] @ [40] . [00] . [00] . [0c] [20]
avrdude: stk500_cmd(): programmer is out of sync
M@!
This is the error I received when I tried using RA Wizard
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 27,026 bytes (of a 30,720 byte maximum)
C:\Program Files\Reef Angel Controller222\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller222\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM5 -b57600 -D -Uflash:w:C:\Users\mroit\AppData\Local\Temp\build6813089937748313509.tmp\sketch_nov11a.cpp.hex:i
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
avrdude: Recv:
I can tell you got the wrong board...
Make sure you select Reef Angel Controller w/ optiboot
M@!
I changed to w/ optiboot and I'm getting the same error, any ideas?
M@!
Of course windows 7 is not displaying my Com Ports. I'll need to keep digging for port info.
M@!
I decided to just give it a try on my mac, received the following error:
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 26,310 bytes (of a 32,256 byte maximum)
avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x8a
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x10
avrdude: stk500_cmd(): protocol error
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
M@!
I have no clue how to look up port info on my mac. Let me see what I can find.
Go to menu Tools->Serial Port
Which ones do you have and which one is selected?
M@!
Alright, finally have time to mess with this again after the Holidays. I'm back on the PC. I have 200+ ports available. Is there a specific port I should try?
Right the unit has power and the status light is just blinking red.
How did you end up with this many ports?
You were supposed to have just a few if not one.
M@!
No clue, I have 256 available.
M@!
What next step for trouble shooting?
Do you have RA or RA+?
Make sure to select the correct board under menu Tools->Board.
Also, please make sure that you have the correct com port selected under menu Tools->Serial Port.
M@!
Regular RA. Well I got it working again. I loaded this sketch
After I loaded that sketch I was able to load the preloaded code. Then the wizard code loaded. No clue what changed but thank for your time. I'm going to setup this up on my tank this week and hopefully no more issues.
