Custom vortech modes
Appleseed
Post by Appleseed »
Hello,
I currently have my mp40s running in differant modes at various times to of the day;
for example:
 else if (hour()>=0 && hour()<1)
            ReefAngel.RF.SetMode(Lagoon,50,15);
         else if (hour()>=1 && hour()<2)
            ReefAngel.RF.SetMode(Lagoon,40,20);
         else if (hour()>=2 && hour()<3)
            ReefAngel.RF.SetMode(Lagoon,30,25);
         else if (hour()>=3 && hour()<4)
         else if (hour()>=4 && hour()<5)
I would like to use the custom mode at specific times for each of the channels.
So for example sake between 4 & 5 am I might like the following;
SetMode(Custom,30,0)
SetMode(Custom,60,1)
SetMode(Custom,40,3)
and between 5 & 6 am:
SetMode(Custom,60,0)
SetMode(Custom,30,1)
SetMode(Custom,80,3)
and so on...
The question I have is how to do it? I tried the following;
else if (hour()>=5 && hour()<6)
But (I guess for obvious reasons) it does not work.
My guess is I need to define a variable alone the lines of the following;
Cust_1 = SetMode(Custom,30,0) ;SetMode(Custom,60,1);SetMode(Custom,40,3)
Cust_2 = SetMode(Custom,60,0) ;SetMode(Custom,30,1);SetMode(Custom,80,3)
and then I can run this at a specific time by doint something like the following,
Cust_1
Cust_2
Unless I can just have all three on one line ie
SetMode(Custom,60,0), SetMode(Custom,30,1), SetMode(Custom,80,3)
SetMode(Custom,30,0), SetMode(Custom,60,1), SetMode(Custom,40,3)
Which I have not tried tbh.
Any help is appreciated.
cheers
Andy
Re: Custom vortech modes
Humm... That's a tricky one :)
Let me think about it and check how the custom code underlying code works. I already forgot :(
But, I know that channel 3 doesn't exist.
Channel 0 = sync
Channel 1= anti-sync
Channel 2 = back-of-tank
Just as curiosity, what happens when you use this:
ReefAngel.RF.SetMode(Custom,30,0)
ReefAngel.RF.SetMode(Custom,60,1)
ReefAngel.RF.SetMode(Custom,40,2)
Appleseed
Post by Appleseed »
Sorry my bad i know its 0-2 any how i tried to verify the code and got the following error;
Ninth_attempt.cpp: In function 'void loop()':
Ninth_attempt:234: error: 'else' without a previous 'if'
          else if (hour()>=19 && hour()<20)
            ReefAngel.RF.SetMode(Constant,40,10);
          else if (hour()>=20 && hour()<21)
//          ReefAngel.RF.SetMode(Constant,30,10);
            ReefAngel.RF.SetMode(Custom,30,0);
	    ReefAngel.RF.SetMode(Custom,90,1);
	    ReefAngel.RF.SetMode(Custom,150,2);
          else if (hour()>=21 && hour()<22)               ///<Line 234
//            ReefAngel.RF.SetMode(Custom,30,0);
//	    ReefAngel.RF.SetMode(Custom,90,1);
//	    ReefAngel.RF.SetMode(Custom,150,2);
          else if (hour()>=22 && hour()<23)
A if statement that has more than one line needs to be enclosed in {}
Appleseed
Post by Appleseed »
Thanks Roberto I can verify the code so it will hopefully work.
Next question I have is I would like to change the speed every 15 minutes, so for example sake at 5am i would like it to start as follows:
then 15 minutes later change to
ReefAngel.RF.SetMode(Custom,40,0)
then
ReefAngel.RF.SetMode(Custom,50,0)
etc
Can you suggest how I can do this following the lines of may else if (hour() ... ?
Also am I in danger of making the program too "large"? . I have the plus controller.
cheers
Andy
You can use slope and have it gradually increase. Wouldn't it be better?
ReefAngel.RF.SetMode(Custom,PWMSlope(5,0,17,0,30,100,70,0),0);
Appleseed
Post by Appleseed »
that sounds like a plan. can you explqin what the variables are. im guessing start at 5 am finish at 5 pm. start % 30 end% 100 but not sure about the rest.
cheers
Andy
Appleseed
Post by Appleseed »
thanks, i will give that a go.
TanksNStuff
Post by TanksNStuff »
Hmm, I didn're realize you could use PWMSlope as a variable for other functions. That's interesting and if I ever get some free time I might experiment with this.
I'm guessing you could also do the same thing with Parabola too?
yeap :)
