PWM Expansion needed?
najluni15
Hi,
I am planning a new build with 4 Meanwell drivers, or 4 Steve's LED drivers. Is it possible to connect 2 drivers into EACH PWM channel already included with my current Reef Angel? And if so, how would I do this.
Thank you so much.
Thank you so much.
najluni15
Re: PWM Expansion needed?
Is there a limit to how many I can connect to each PWM channel? I plan on having three drivers for one channel, and another 2 on another channel for around 60 leds total.
Thanks so much. Your support is awesome as always...Now this enables me to pick up a wifi adapter instead of the pwm!
There is but you should be fine with 3.
The limitation is 40mA draw from all drivers when they are at 100%.
Each meanwell I think draws around 3mA.
najluni15
Thanks Again! And do you know if it is possible to dim the meanwells to 0%? Apparently they cut out at 15%, according to another thread. Im trying to decide between the Steves LeD Drivers and the mean wells.
LPF series is supposed to go down to 3%. ELN series cut off at around 15%
I've heard Steve's go all the way to 1%.
Since you brought up Steve's...let me hijack with a quick question...can you have a pot and pwm with the meanwell's? Steve's has a separate input for a manual dimmer in addition to the pwm input...
Really?lnevo wrote:Since you brought up Steve's...let me hijack with a quick question...can you have a pot and pwm with the meanwell's? Steve's has a separate input for a manual dimmer in addition to the pwm input...
You can have both?
najluni15
What is the difference between the LPF and ELN series? Sorry if this is unrelated to you, but it seems like you know a lot about it...
Right after I posted, I was like, duhh!!??
Of course you can.
If you pot the dimming signal, you get to feed the driver a % of the dimming signal, which makes it double dimming if you will... lol
Of course you can.
LPF is their newer model. Never used it though. Sebyte (Steve) and 00Warpig00 (Nick) are using them.
http://forum.reefangel.com/viewtopic.php?f=2&t=788
najluni15
Ill have to look into it. Thanks!
