If the controller is displaying C then it's sending C to the client. Inside the Client, you can configure F or C. You will just need to change it inside the Client then things should work for you.pasqualevg wrote:A little note:
Probably something in the libraries is blocking the sending of memory params of Heater & Chiller on & off in °C, probably is set to °F and if it read f.e. 255 think that's wrong.
I don't know if the problem is in the libraries or in the client...
I'm not sure if there is a setting for the web banner to have it display C instead of F. That's something Roberto will have to answer.
