Need custom code for custom expansion
Re: Need custom code for custom expansion
I'm also interested on seeing how you are powering the motors. Did you use a mosfet transistor?
No I use a NPN transistor TIP-122rimai wrote:I'm also interested on seeing how you are powering the motors. Did you use a mosfet transistor?
Here is the wiring I did
![Image](http://img.tapatalk.com/d/12/10/26/puru5ege.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/e7ygevu6.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/uby3abev.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/3a4etu2a.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/adenety9.jpg)
Thank you very much for your comment
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
For control motor speed with PWM you need:
1x NPN transistor TIP-122
1x Capacitor 1uf
1x Diode
1x Resistor 1k ohm
And the diagram
![Image](http://img.tapatalk.com/d/12/10/26/azyzurez.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/ujy7y5un.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/2e8u9epy.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/uty5ynar.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/teqe2unu.jpg)
For make your own USB cable for communication RA/Uno
You need:
1x Regular USB cable and strip it
2x Resistor 1.5k ohm
And the diagram
![Image](http://img.tapatalk.com/d/12/10/26/anamezyr.jpg)
1x Capacitor 1uf
1x Diode
1x Resistor 1k ohm
And the diagram
You need:
And the diagram
Hi guys, I did some experiment for you. And the good news, you can use the dimming ports of Reef Angel to control the motor speed. You do not need an Arduino Uno. The Reef Angel and pwm expansion module is ready for this use.
Here the diagram
![Image](http://img.tapatalk.com/d/12/10/26/u3ygu9y6.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/a2y7u4yr.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/gujutyne.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/zunynusy.jpg)
![Image](http://img.tapatalk.com/d/12/10/26/janu9e2e.jpg)
And the video
http://youtu.be/Zo3RXFuEGlI
I think if would be great for an update of RA dosing pump![Wink ;)](./images/smilies/icon_e_wink.gif)
Here the diagram
And the video
There you go roberto! Wire that into the circuit for of the ra dosing pump add a switch for controlled or independent mode and done deal!!!
I need your help, I'm not very good with the RA code.
I would like to know if it's possible to add to the menu PWM port and change the name in the menu?
Ex: instead of Ch 0, Ch 1, Ch 2 and Ch 3
I would like Alk, Ca, Mg and Carb and to modify the duration and %
Ex: Alk 15sec at 100% or Ca 20sec at 60%
Thank you in advance
Eric
This is my RA code
Eric
This is my RA code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port8,0,60,60 );
ReefAngel.PWM.SetChannel( 0, now()%3600<15?80:0);
ReefAngel.PWM.SetChannel( 1, now()%3600<25?50:0);
ReefAngel.PWM.SetChannel( 2, now()%3600<35?95:0);
ReefAngel.PWM.SetChannel( 3, now()%3600<10?100:0);
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
I'm assuming you are talking about changing the main screen, right?
http://forum.reefangel.com/viewtopic.php?f=14&t=109
Yeah and change the value of PWM expansion, on ch0, ch1, ch2, ch3 directly on PDE.
thank you I'll try to make my own main screen and menu.rimai wrote:I'm assuming you are talking about changing the main screen, right?
