LCD Contrast
Bryan
LCD Contrast
Is the contrast for the Nokia stored in EEPROM anywhere or is the default value of the LCD used?
-=Bryan=-
- Contact:
Re: LCD Contrast
Default value is used. It could be stored in EEPROM but it's not currently. In fact, this hasn't even been brought up until now.Bryan wrote:Is the contrast for the Nokia stored in EEPROM anywhere or is the default value of the LCD used?
Bryan
Re: LCD Contrast
I finally got around to hooking up the RA LCD and found it quite bright, contrast needs adjusting or will need to adjust the regulator to drop the voltage to the backlight.
-=Bryan=-
Bryan
Re: LCD Contrast
Yes, thanks that is what I am doing, seems to look best at (30). Just thought for some reason the value was stored in EEPROM.
-=Bryan=-
