Pumps shutting down briefly
treetopflyn
Post by treetopflyn »
For the past few days (Only had the controller a little over a week) when the room is quite and I am working every once in awhile (4-5 times now) I will hear a click and pumps shutdown for a VERY brief second and then return to normal. The glitch doesn't show up on the relay log. I don't have lights hooked up to is so I don't know if its the whole relay or only certain outlets. Any ideas what could be causing it.
Re: Pumps shutting down briefly
Can I see the code?
treetopflyn
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 889 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO( Port1,60 );
if (hour()>=21 || hour()<7)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.WavemakerRandom1( Port5,30,90 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.Relay.DelayedOn( Port7,0 );
ReefAngel.Portal( "treetopflyn" );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
Do you have any idea of which ports?
What do you have on port 7?
treetopflyn
Port 7 is a skimmer. Not sure which ones but I know for sure the return pump on 2 is
Does it turn on/off properly when you go through feeding or water change mode?
treetopflyn
Yes everything works as programmed, it just randomly glitches.
Piper
Post by Piper »
Make sure your connections are all tight to the relay box(es). I had strange things happen when I first set mine up and it ended up being a lose connection to a relay box. I pulled all the cables apart and plugged them back together and everything has been working great since.
~Charlie
treetopflyn
Thanks Piper I will give that a shot.
treetopflyn
Still doing it and seems to be getting worse. :-(
I wonder if this is the same as this:
http://forum.reefangel.com/viewtopic.php?p=16174#p16174
treetopflyn
still having the issue :-(
did you remove the jumpers?
treetopflyn
No. That entails taking the controller apart correct?
Yes, but it is just 4 screws in the head unit.
You unscrew and open the enclosure and it will be right there.
